2000 Maxima Automatic - shifting issues
Old Dec 13, 2004 | 09:03 AM
ILikeStuff's Avatar
I fear for the life of my transmission and was wanting some advice. At times when the car is shifting from first to second, it seems to rev quite a bit higher than normal and then shift with a clunk and a jerk. It has been doing this for quite some time. usually it only does it if I'm really getting on it, but occasionally it does it when driving normally. I did a flush and fill of the transmission oil within the last 6000 miles, but it didn't seem to help. What is going on? Would it be worth taking to a transmission shop to have it looked at?
Old Dec 13, 2004 | 09:47 AM
unrealii's Avatar
You can look here for any technical service bulletins:
http://maxima.theowensfamily.com/tsb/
I honestly do not know where the best place to take your car if it is out of warranty.
Old Dec 13, 2004 | 09:59 AM
ILikeStuff's Avatar
Thanks, i see the tranny slip is in the list and has a couple of possible fixes. Thanks for the info!
Old Dec 13, 2004 | 10:36 AM
Max_Vader_2K's Avatar
Had the same issue. took it to a dealer with the svc bulliten and problems was solved.
Old Dec 13, 2004 | 10:58 AM
dennisuello's Avatar
did you get both TCM and solenoid valve assembly replaced or just one or another?
does anyone know how much it would cost for dealer to do?
is it hard to do yourself?
Old Dec 13, 2004 | 11:51 AM
Maximum Performance's Avatar
i have the same problem on the beater SE that i bought
its a 2000 with 27K
luckily its under powertrain warranty till may of 05 (5 year 60k)
went to the dealer, tech drove it, said it needs a new trans, trans came in today and i just dropped of the car to get the new trans to be put in
Old Dec 13, 2004 | 01:15 PM
upstatemax's Avatar
i had same prob, i brought it to the dealer and they reprogramed the TCM i think... i also needed to replace the tranny fluid from all the slipping... it was burnt to crap
... I want to do this to Nemith Motors...
Old Dec 13, 2004 | 01:25 PM
Loe max's Avatar
In the mean time if you want to protect your transmission...
When you sense the 1-2shift is about to happen, let off the gas. Why? Because it won't allow the engine shoot revs between the upshift. Otherwise use the '1' and '2' gate to upshift while letting off the gas. Yes it sounds like you are a fakAr manual, but it'll keep your engine to shoot revs between that shift until you get your TCM reprogrammed or a new TCM.
Old Dec 14, 2004 | 08:22 AM
the latest thing that my Max is doing is when i start from complete stop and put the tranny into 1st, floor it, it accelerates fine untill about 4500RPM, then it acts like it's gonna shift, but it doesn't cause it's in 1st. is this tranny related or the infamous VIAS problem?
Old Dec 14, 2004 | 10:54 AM
mike_747's Avatar
Try putting in some Lube Guard. I've used if for years and my tranny shifts very smooth. Any decent tranny shop will have this stuff - only about $15/bottle.
Old Dec 16, 2004 | 11:59 AM
97Se5spd's Avatar
i have the same problem with my 2000 auto it only does it wen its warm and between 3000 3500 rpms. it only happens from first into second the revs dont go up that much but they do car only has 50000 on it think i need a new trans? or is it the TCM?
Lakersallday24
Jun 16, 2019 01:35 AM
Trin1j23
Aug 12, 2015 08:31 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
