2003 Maxima SE front Brakes
Old Dec 14, 2004 | 01:04 AM
Redstone's Avatar
Has anyone ever changed the front brakes on a 02 or 03 Maxima SE or GLE? I am planning to change my front rotors and pads, but might need a bit of advice on removing the rotors. I took a quick look a few weeks ago to see how to remove the pads and rotors. Like most cars the pads were pretty simple to remove. However, the rotors didn't appear to have any screws that would allow for removal. I am thinking there must be some simple trick to it. If anyone has ever done a brake job on any 5th Generation Max especially the 02's or 03's, I would like to hear your suggestions on removing the rotors. Thanks!
Old Dec 15, 2004 | 12:31 AM
aussie983's Avatar
www.motorvate.ca The brake setup is pretty much the same.
Old Dec 15, 2004 | 12:35 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Remove the calipers and the rotors come right off. May need to pursuade them with a rubber hammer. I replaced front and rear rotors/pads on my '02 with an iRotors setup. Check my site for pics.
Old Dec 15, 2004 | 11:50 AM
ddpack's Avatar
Look in the "how to's" there is plenty of info & pictures there to guide you in the process.
Old Dec 15, 2004 | 09:01 PM
Maximax2's Avatar
Yep, sometimes have to use a rubber mallet to jar them loose, then they come right off. I have a lot of experience with brake jobs, tend to drive kinda fast...
Old Dec 15, 2004 | 09:11 PM
scopium
remove the calipers
and then there are 2 other screws that hold in the second part.. you can see them
just few taps on the rotor and just pull it out evenly from all sides
Old Dec 15, 2004 | 11:40 PM
Redstone's Avatar
Thank for the info guys. I appreciate it. Everything was a success.
03VQMAX
Sep 25, 2015 04:19 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
09maxshawn11
Aug 9, 2015 01:13 PM
Jcof88
Aug 3, 2015 10:43 PM
