cam question
Old Dec 14, 2004 | 12:53 PM
super maxi-pad's Avatar
cam question
i have a 2001 GXE automatic, and ive noticed the power band is real abrupt low in the RPMs. ive been wondering if i were to put a pair of cams with a wider lobe pattern and spead the powerband throughout the RPM's, it should help higher RPM horsepower, while still retaining enough torque to still get that great maxima launch. has anyone gone down this path and if so, what is a good cam profile for an every day driver/street race performance. id like to have more of the powerband focused on high end HP with out completely sacrificing lowend torque.
Old Dec 14, 2004 | 12:58 PM
Loe max's Avatar
Can you go more into detail with that description?
V
Old Dec 14, 2004 | 01:23 PM
PearlWhtMaX2000's Avatar
do they evan make cams forour cars?
Old Dec 14, 2004 | 01:49 PM
Loe max's Avatar
I believe JWT makes cams for 4th gens. I believe they can be used in 5th gen VQ30's also
Old Dec 14, 2004 | 02:40 PM
GreenSeMax's Avatar
yeah JWT is our only option now, you could probably get a custom set made by one of the big manufacturers, Tomei, Toda, maybe even the domestics like Comp or Crane if you dare.
Old Dec 14, 2004 | 03:45 PM
how much do those cams go for? and are they worth it? websites???
Old Dec 14, 2004 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
Your best bet to keep both low and high end is what Tilley did, check the all motor forum.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
