Exhaust system worth it?
Old Dec 20, 2004 | 01:48 PM
aarciga's Avatar
I heard someone comment on here that maximas allready have a free flow exhaust system, so getting a new one is would be a waste of money.
what are other peoples thoughts? I dont wanna go shell out 500 bucks to find out i didnt upgrade very much.
Old Dec 20, 2004 | 02:21 PM
aussie983's Avatar
The stock muffler is pretty free flowing. Its mainly the emissions stuff that limits the performance. Best bang for buck is just to get a Y-pipe.
Old Dec 20, 2004 | 02:33 PM
aarciga's Avatar
would a high flow cat be a good improvement?
Old Dec 20, 2004 | 02:40 PM
2kGLE's Avatar
Go look under your car at the b-pipe and see the crimp where the hanger is. Then, go smack the person who told you it would be a waste of money. Check out Budget Exhaust for a ypipe (~160USD), test pipe (~20), and b-pipe (~160). Add an intake and thats a solid 25whp IMHO. If you hav the cash, get Cattman headers instead of the y-pipe. If you dont want a test pipe, yes a high flow cat is better than stock but not a huge improvement. Just my .02
Old Dec 20, 2004 | 02:41 PM
NYC TAR's Avatar
OEM cat is also hi flow
it just pre car (the y pipe) and headers that need to be change ( header are more useful for 02-03 max) plus, header comes with y pipe.
Old Dec 20, 2004 | 07:30 PM
aarciga's Avatar
so it would not be worth getting a new F pipe, but rather just a B and Y
Old Dec 20, 2004 | 07:37 PM
aarciga's Avatar
I was looking at replacement Y pipes, and on 2kracing they sell a stillen one for nearly $400, why is one 160, and the other so much more? is it that much better or is it jus for the name
Old Dec 20, 2004 | 08:14 PM
ibag8rfan's Avatar
that stillen one is a total rip off. Get a Budget unless you can afford Cattman. Cattman is over $300 but most people will tell you it's worth the extra money. Stillen has been proven to have minimal to no gains.
Old Dec 20, 2004 | 08:45 PM
BeSeenWithGreen's Avatar
Any one have link for budget exhaust please? Thanks
Old Dec 20, 2004 | 09:22 PM
aarciga's Avatar
What would be preferable, a Cattman Y pipe, or a Budget B and Y pipe
Old Dec 20, 2004 | 09:23 PM
aarciga's Avatar
Also what makes one pipe better than another?
Old Dec 21, 2004 | 02:11 AM
aussie983's Avatar
Budget is supposed to be SS, but ive heard theres is this small section that rusts easily. This shouldnt be too much of a problem since ur in cali . Check the 5th gen for sale forum. I think i saw someone selling his budget y pipe somewhere in norcal.
Old Dec 21, 2004 | 03:26 AM
aarciga's Avatar
checked the for sale section didnt see anything about it.. oh well
Old Dec 21, 2004 | 03:56 AM
aussie983's Avatar
http://forums.maxima.org/showthread.php?t=361531
Old Dec 21, 2004 | 07:30 AM
SPiG's Avatar
SomePsychoGuy
Replacing cat will do basically nothing unless you have turbo, SC, or N2O. Test pipe is if you want your car to sound worse and smell. Y pipe and B pipe are the best things to replace. Change muffler if you want your car louder. Get a Resonator in the b pipe if you have new muffler. It sounds better IMO.
An F pipe is just another name for a y pipe. F is more descriptive of what it looks like on a front engine FWD while Y is closer to Front engine RWD. Most people on here just call it Y.
http://maxmods.dyndns.org/index.php?MaximaPerformance
Old Dec 26, 2004 | 12:24 PM
aarciga's Avatar
I am going to get the cattman, can it be installed by me? or should i get a pro to do it?
Old Dec 26, 2004 | 02:57 PM
GreenSeMax's Avatar
it's not hard to do, but your hardware may be rusted on there, or otherwise seized and in that case you'd want air tools, (air ratchet or impact gun, i used an air hammer to break the nuts loose) It's real easy to put on, and you'll love the results. And if you doubt the test pipe's effectiveness, check this out http://www.customenterprise.com/view.../vts/design004
and I'd recommend the Greddy Evo2, it's stainless, and the straight through design produces more power than the traditional muffler style systems. And it's doesn't have the problems of banging on the floor, supports, or suspension components like cattman has been known to. On the contrary their Y is probably the best made for our cars. I have the stillen and i've had none of the problems people complain about with them. The CM test pipe is nice, doesn't sound bad, i had a bit of an issue getting it to seal because the flange width from the pipe to the edge is too thin, and the inside diameter is huge, much larger than necessary but it is like a resonator, as they advertise.
Old Dec 27, 2004 | 01:23 PM
aarciga's Avatar
where can i buy a greddy test pipe?
EDIT: also, what kind of HP can i expect to gain with a cattman y-pipe
what kind of hp gain are expected with a budget y-pipe,
Old Dec 27, 2004 | 06:40 PM
MasterAv's Avatar
I have a Brand new 2k-2k1 Budget testpipe for sale. . PM me if you're interested
Old Dec 30, 2004 | 10:46 AM
maximillus's Avatar
how good is the y pipe that comes with the cattman headers?
Old Dec 30, 2004 | 10:57 AM
GreenSeMax's Avatar
most y-pipes of the same diameter will provide similar gains, if anything Cattman's slightly superior merge collector could give you a hp or two perhaps, and greddy doesn't make a test pipe i know of for the max
Old Dec 30, 2004 | 12:59 PM
Maxi113's Avatar
With a testpipe on you won't pass emissions..Well at least here in Chicago you won't..I have a Greddy Evo Exhaust system with a stil y and it sounds pretty loud and mean...As for hp gains beats me..
Old Dec 30, 2004 | 01:07 PM
Larrio's Avatar
The Definitive AE Master
Thats referring to the stillen headers, not the y-pipe. Their y-pipe shares a similar design to the cattman and the budget, no negligible differences between y-pipes except price.
Numerous members of this forum run the stillen y-pipe with proven gains. I have a 12whp increase with just a stillen y-pipe
Old Dec 30, 2004 | 01:52 PM
GreenSeMax's Avatar
I have the stillen y, no noises, no banging(which i know is a noise), and after 3 months, one of those all nice and salty it still looks new. no dyno's to proove it but the stillen/test pipe/Evo2 combo sounds great, and pulls hard. Larrio do you have a dyno before/after perhaps?
Old Dec 30, 2004 | 02:50 PM
mdloops's Avatar
25 WHP?? don't make me laugh too hard...
Old Dec 30, 2004 | 04:23 PM
Larrio's Avatar
The only file I have would be my most current one done this month (intake, y-pipe, TS ecu). My stock one was a print out and I don't have that one on me anymore, I just remember the peak hp/tq
I like the stillen y-pipe because its ceramic coated
Old Dec 30, 2004 | 04:29 PM
sooner02r1's Avatar
You also have blue graphics on the side of your car.
Old Dec 30, 2004 | 07:02 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
25WHP is pretty accurate, cause the Ypipe alone is in the vicinity of 15-18WHP on the 00-01 Maxima, we are talking 3.0L here. Bpipe is pretty restrictive right past the resonator where it crimps down to about a 1.5" in diameter and then goes back to like 2.12".
If you wanna buy a Greddy, I'm sellin mine for 250 local, its seeing its 1st winter right now, about year old, its the EVO1- full catback, with no rust.
Old Dec 30, 2004 | 07:11 PM
mdloops's Avatar
oh. I thought we were talking about 3.5L. I would believe about 20WHP for y and catback on a 3.0L
Old Dec 30, 2004 | 08:26 PM
2KGLE has a 00 Maxima GLE with a 5spd conversion on it, he like me and some other .org members knows wtf hes talking bout when it comes down to mods n 5th gens. Ypipe on a 3.5L makes like 8-10WHP, exhaust will make about 10WHP, but you can't just expect 20WHP more with both on a 3.5L, you will be lucky to make 15WHP more with both installed. Ypipe, intake, exhaust make around 215-223WHP on a 3.5L. Headers make alot of power on the 3.5L, and they are still pretty good on Cali Spec DE-K engines- since we have a precat in one manifold and 3.5L has em in both.
Old Dec 31, 2004 | 05:08 AM
GreenSeMax's Avatar
will 3.5 headers fit a 3.0, other than the likely 02 relocation?
Old Dec 31, 2004 | 02:01 PM
Larrio's Avatar
its actually the other way around. The cattman 3.0 headers fit the 3.5 also. The hotshot 3.5 headers have been fitted to a 3.0, but not quite the right fit due to o2 sensor locations
Old Dec 31, 2004 | 02:20 PM
dansmax2003's Avatar
Great....what about warranty?
I 've been reading about Y-pipe and other exhaust modifications for months now and i'm thinking about investing some money in my Cali spec '03 Maxima with AT.
The only BIG concern i have is the fact that i have Gold + Warranty which i still haven't used. (knock on wood).
I am afraid that if i touch the exhaust my warranty will go away and this is something that i do not want to happen.
My qyuestion is... has anyone who has extended warranty done a Y-pipe mod on his Maxima and were there any consequences? Also, how hard is to put back the OEM Y-pipe/exhaust in case i decide to take the car to the dealer for warranty work?
And last.... how would a Y-pipe affect the Gas Mileage on my '03 Maxima?
Thank you in advance!
Old Dec 31, 2004 | 02:29 PM
Gas mileage will go up, cause the engine will be more volumetrically efficient due to increased power from less backpressure.
As far as warranty goes, they can't blame you headers, exhaust for lets say a check engine light for a MAF sensor, or for anything else. They could blame you for any codes that have to do with cats, or 02 sensors. Thats bout it, everything else is covered- radio, suspension etc. Exhaust repleacement has nothing to do with your radio - bose, blowing up or your climate controll not working. They have to PROVE that the exhaust is what made the part on your car to fail. Most dealers scare people away this way, but they have to be able to prove in court that yes this exhaust system, or Ypipe is what made your POS BOSE head unit go bad. Now you tell me how do you think they are going to do it ? I've has NOS, diff clutches, all kinds of weird crap on my Max when it had warranty still, they have had no problems in doing all the little warrnaty stuff to it.
Old Dec 31, 2004 | 02:53 PM
aarciga's Avatar
blackbirdVQ-
what are u selling for 250?
whole catback for 250?
Old Jan 3, 2005 | 11:16 AM
Puppetmaster's Avatar
blackbirdVQ-
If things don't work out with Blackbird... I'm selling my GReddy Evo cat-back for $225 plus shipping....
Old Jan 3, 2005 | 12:06 PM
sublimer's Avatar
I need to replace my muffler so I was just going to get one from Cattman or Frankencar, but is getting the whole catback worth it? Will the gains be worth the extra $$$?
Old Jan 3, 2005 | 03:22 PM
gabe22's Avatar
i just had my buddy install my cattman y pipe and all i can say is, mmmmm daddy likes!!!! lol ... ive been reading the 3.5's are getting minimal gains but my butt dyno tells me different. i can DEFINETLY feel the torque increase. the install was something i could of done myself and im not mechanically inclined at all... just shot the bolts with PB blaster and the bolts broke lose no problem, fitment was perfect and so far no SES ... headers would be nice but after getting a good price for the y pipe from the org classifieds im completely satisfied with my new mod!!!!
Old Jan 4, 2005 | 12:31 PM
2KmaximaSE's Avatar
LOL... OK that does it im getting my y pipe very soon since headers won't help my 3.0
Old Jan 4, 2005 | 12:43 PM
NmexMAX's Avatar
dot dot dot ...
Rule of thumb headers are the best for 3.5s since the have both pre cats in the manifold, and y-pipes are best for 3.0 since they do not have both pre-cats in the manifold.
