Mods?
Old Dec 26, 2004 | 05:15 PM
Howard's Avatar
Mods?
Hi Folks:
I am new to the group. Great info here.
I have an 02 6 speed SE. Never did a thing to it.
Thinking of lowering it a bit. Would also love to give the steering a bit more of a German feel.
Any thoughts?
All help appreaciated.
Also..I get about 28 MPG at 80 on highway. Is that good? Can a different airfilter make it better?
Best,
Howard Adamsky
Old Dec 26, 2004 | 06:19 PM
irish44j's Avatar
retired moderator
Howard...welcome.
A few comments:
1. It is difficult to give the Maxima a "German" feel because as you might know, BMWs and other German cars use a frame/body construction, while the maxima uses a "unibody" construction. Unibody has inherently more body flex....
In terms of "performance sedans", generally...
German = stiff frame, soft springs, stiff struts
Japanese = soft frame, stiff springs, ?? struts.
The best way to give the maxima a more "european" feel is a combination of several suspension/body mods...:
- Stage I/II subframe connectors (stiffen frame)
- Lower tie bar (stiffens steering area)
- Rear sway bar (reduces back end body roll)
- Springs (something like Maxspeed/H&R are ideal for this full setup, in my opinion, and don't lower you all that much)
- Struts (Adjustables like Tokico Illuminas allow you to tweak the rebound rate/firmness)
- strut tower brace (further stiffens front body)
- lower-profile tires (on bigger rims)
I have all of these except the SFC's and rims, and am still not at the level of precise handling that one would feel in a BMW or other high-end german sedan. Supposedly the SFCs make a big difference to this end.
not sure what you mean by "german" steering feel....but the LTB certainly makes the steering more responsive/tighter, as would replacing all the bushings with poly ones.
Also keep in mind that most german sedans are RWD/AWD, while we have FWD....so the dynamics of the steering will always be different due to torque steer, etc....
As to 28mpg...I only WISH I ever got 28mpg...23-24 combo city/hwy is the norm for me, and I've never seen over 26, even on long road trips
For authoritative site on springs/struts, check out Housecor's site: http://www.innerbean.com/housecor/sp..._decision.html
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
