Maxima knowledge
Old Dec 27, 2004 | 09:04 PM
twllin's Avatar
Maxima knowledge
Any one have the knowlege of how to program a key for a 2K
Im gettin my remote start installed this weekend and i dont wanna pay nissan 50 bux jus to do it when ithink someone here can help me out.
thanks
Old Dec 27, 2004 | 09:10 PM
SoonerFan's Avatar
Cletus
i have the info in the service manual...unfortunatly i am away from home till tomorrow afternoon...if no one tells you before, ill post it
Old Dec 27, 2004 | 09:11 PM
PearlWhtMaX2000's Avatar
i always thought Nissan is the only one who can do it.
P.S. Call me when the coils are in i need them ASAP. Thanx
Alex
Old Dec 27, 2004 | 09:12 PM
twllin's Avatar
Hey sooner that would be very muc appreciated
Perl
No prob man ill call you as soon as i get around to it. Are you sure nissan is the only one?
Old Dec 27, 2004 | 09:14 PM
SoonerFan's Avatar
Cletus
Alex
the only reason nissan is the only one is because they have the manual...it can be done...its some crazy turn the key, gas pedal, turn key on/off ten times, scratch your head, then press the button on the new remote
ill post tomorrow
Old Dec 27, 2004 | 09:15 PM
im not sure but when i got my Compustar auto start put in, i needed the 555U module, and i had to get a programed spare key from Nissan. i looked everywhere elso to see if i can get it cheaper but no luck.
Old Dec 27, 2004 | 09:17 PM
twllin's Avatar
yea i bought the alarm and my parents paid for the install and the modile for Christmas so imma try this
ill post tomorrow
Thanks man and u left out the drink a case of beer before you press the button haha. ANd jus to make sure this is for the key programming not the remote right?
Old Dec 27, 2004 | 09:21 PM
SoonerFan's Avatar
Cletus
WELL DAM IT!!!!! i drank a case of beer before reading this post...thats for the remote...key must be done at dealership for security purposes...chip would be pointless if anyone could program a new key
Old Dec 27, 2004 | 09:23 PM
Yeah thats what i thought.
Old Dec 27, 2004 | 09:28 PM
SoonerFan's Avatar
Cletus
well now ive been wrong on here once...
but its the beers fault
Old Dec 27, 2004 | 09:34 PM
haha ur never wrong Sooner. dont worry u just misunderstood. but Honestly out of the whole time ive been on the org, u ands Irish always give the best responce and info. soo Cheers to that
Old Dec 27, 2004 | 10:00 PM
SoonerFan's Avatar
Cletus
well im glad we can help...its cause we are both "intelligent" goverment employees...and we hang out so we share info back and forth which has made us both smarter
Old Dec 27, 2004 | 10:11 PM
yeah that make sense
Old Dec 27, 2004 | 10:21 PM
FanaticMadMax's Avatar
Nice to have a remote starter, but it's not for me, i just hate to mess up the wiring.
Old Dec 27, 2004 | 10:47 PM
LA02MAX's Avatar
i second that, yall are always the ones who answer the questions right the first time with no confusion...great job and thanks for the help
Old Dec 28, 2004 | 08:45 AM
twllin's Avatar
Damn This Sux Now Im Going To Haev To Fork Out Some Money To Get This Programmed
Old Dec 28, 2004 | 10:01 AM
adithius's Avatar
I got this from the 4th Generation FAQ. Hope this helps Twillin. Any word on 4th Gen coil packs?
I've bought new keyless entry remotes for my car, how do I program them?
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
-remote controller or multi-remote control unit LCU05 is replaced.
-an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Linkage: http://home.earthlink.net/~maxfaq/m...ance.htm#Remote
Credit: Spritemax
Old Dec 28, 2004 | 10:06 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
This works on the 5th gen as well?
Old Dec 28, 2004 | 10:08 AM
Maxpat82's Avatar
ID code entry:
NOTE
Credit: Spritemax
good for remote only!
as sooner as said: only nissan can program the key!
P.S.: bring the car and ALL key when you get them programmed! if it's a new key: they need to reprogram all of them! (computer generate a random security ID everytimes)
Old Dec 28, 2004 | 10:09 AM
Maxpat82's Avatar
Yes for the remote!
adithius's Avatar
I dont see why not. But do at your own risk.
Old Dec 29, 2004 | 09:09 AM
twllin's Avatar
hey guys thanx fro the help but i do need this for thekey not the remote. Oh and thanx fro twellin me i need to talk all keys i wouldnt of known that. I think imma go do this on friday
Old Dec 29, 2004 | 09:34 AM
yeah you will def engoy thr remote start. what system did u get? compustar?
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
julian888
Aug 6, 2015 04:39 AM
