Cattman Headers on a 2k-2k1
Old Jan 4, 2005 | 09:15 AM
GreenSeMax's Avatar
Does anyone have any dyno runs and/or timeslips of a 5th gen 3.0 with Cattman headers. What other exhaust parts are you guys running, and what's your opinions on the sound quality and powerband? What installation issues did you run into? Any info is appreciated.
Old Jan 5, 2005 | 08:40 AM
GreenSeMax's Avatar
noone has these?
Old Jan 5, 2005 | 09:01 AM
NmexMAX's Avatar
dot dot dot ...
I have them, just not on a DEK.
If they can fit the 95 as well as the 03, Im sure the 00-01 iwill be fine since they were originally made for the 3.0.
Old Jan 5, 2005 | 09:17 AM
alicious's Avatar
the org...not what it was
Not really worth the investment, check http://forums.maxima.org/showthread....7&page=2&pp=30
Old Jan 5, 2005 | 09:18 AM
NmexMAX's Avatar
dot dot dot ...
You're better off with a y-pipe. ^^
Old Jan 5, 2005 | 09:22 AM
GreenSeMax's Avatar
I have a Stillen Y as it is, I am going to be tearing down the top end of the motor for port work, and I'm researching cams, but i've found nothing but bad opinions on JWT, which as i find are the only cams available for the 3.0. When the motor is apart I am tossing the idea of doing headers as well, and am looking to see if it will be worth the money mostly, as the labour is all mine, and it'll be apart already. Thanks
Old Jan 5, 2005 | 09:43 AM
NmexMAX's Avatar
dot dot dot ...
The gains haven't been proven on a 3.0L
Old Jan 5, 2005 | 10:51 AM
Haterz's Avatar
The gains are there, I have them on my de-k and more than happy with the gains and the sound is great as well. My friend has a y-pipe, to me it doesn't even compare.
Old Jan 5, 2005 | 12:27 PM
alicious's Avatar
Gains in which end exactly?
Old Jan 5, 2005 | 12:57 PM
Larrio's Avatar
The Definitive AE Master
butt dynos and head-on street races do not count.
dyno or drag strip trap speeds are the only true indicators
Old Jan 5, 2005 | 01:09 PM
2kGLE's Avatar
Brian Catts did a comparison between his ypipe and headers on his old 4th gen 3.0. Yes there were gains. There would be even bigger gains on a DE-K.
Old Jan 5, 2005 | 02:00 PM
MyownNismo's Avatar
Future Camaro SS owner
Like I had talked with Blackbird that I have headers waiting to go on (winter here) Spring they will go on. I will be doing a before and after dyno.
Old Jan 5, 2005 | 02:11 PM
doublea's Avatar
You should see gain of around 15-20 HP over the Y-pipe, I'll know for shure very soon, since I'll be switching from Y-Pipe to Headers, with FI the gain should be even more and that's why I'm switching to Headers soon because FI is on the way.
Cheers
AA
Old Jan 5, 2005 | 03:15 PM
NmexMAX's Avatar
dot dot dot ...
Unless someone can provide me with a dyno (besides cattman) or track time, I'm not convinced.
Larrio's right.
And hopefully MyownNismo will prove me wrong, as this will be yet another good power adder for the DEK.
I'm not hating on the headers just want to see proof, like anyone else would before shelling out the $$ .
Old Jan 5, 2005 | 03:17 PM
MyownNismo's Avatar
Bad news is if I prove it makes power you'll be paying more since the price is going up. That was stated by cattman in there last GD where I got mine for $700.00.
Old Jan 5, 2005 | 03:21 PM
NmexMAX's Avatar
dot dot dot ...
Hopefully the NZ dollar and US dollar will come to close terms to keep the price the same or lower.
I already have them on my 3.5L but for others that want them .
Old Jan 5, 2005 | 03:43 PM
Larrio's Avatar
my belief that a de-k NA will see gains after the VI is open in the higher rpms after 5k. Anything before that is negligible give or take a few hp/tq
Old Jan 5, 2005 | 04:49 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I am going to go do a baseline run this coming week as soon as the weather gets nicer, my heavy snow tires will throw off the reading I think. I'm going to be comparing my current Cattman Ypipe to HS headers- I boycotted Cattman 2 months ago. This will be a highly modified DE-K, with no power valve installed, so my low end power aint going to be all that great. I reather have issues with fitting the headers on my car (HS), than spend more and get less. No more Cattman for me.
Old Jan 5, 2005 | 06:00 PM
MyownNismo's Avatar
That's why I have my Apex-i RSM setup to activate the VI earlier. I am going do some runs as soon as I get the SAFC tuned. If all else fails add a SC as hnda etr did and made more with the headers.
Old Jan 5, 2005 | 07:29 PM
Kevon1's Avatar
Wow
Wow first person I have seen complain about a Cattman product. I have there Catback & Y-Pipe & love it fitment was excellent as well as customer service. Brian was great. If you dont mind me asking what has you soured on Cattman?
Old Jan 5, 2005 | 08:08 PM
chris'smax's Avatar
bro if you don't mind, after you do the install can you send me some directions for the modifications that are needed. I am probably going to buy mine tommorow.
Also why do you say pay more and get less for cattman? Are the hotshots suppose to be of better quality?
Old Jan 5, 2005 | 08:09 PM
chris'smax's Avatar
whoa back the truck on up, you can use the RSM to activate the VI? Please explain because i would love this!
Old Jan 5, 2005 | 08:18 PM
I have a problem with spending 900 bux for a product like Cattmans when I can get the same thing for 500 bux, I might need to modiffy the 02 sensors a little bit. I will let you guys know the outcome, I'm going to atleast get a dyno of before n after.
Old Jan 5, 2005 | 08:57 PM
Haterz's Avatar
The price is high, especially when someone can make them in stainless for a V6 altima (similar headers) for under $180. I'm sure fitment may be a problem at this price though.
Linky> http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Jan 6, 2005 | 01:09 PM
MyownNismo's Avatar
Go to all motor section look for my thread on what activiates the power valve. Basically the RSM has a switched RPM output. You can set that to a desired rpm. That output is 12V, the power valve is ground. But a know how to use a relay to switch 12v to ground. Haven't got everything ready yet been kinda lazy. got alot of project and no time. But info is there to help you out. I will post up how to use relay once I find my MECP book.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
Chaka
Sep 17, 2015 09:53 AM
Samedi
Sep 3, 2015 01:07 PM
