Simple brake question
Old Jan 6, 2005 | 11:53 AM
NoMotive's Avatar
I'm down to 20% pad life in the front so i'll have to replace them soon. I don't plan on upgrading my brakes, I just want the pads replaced. Some people have advised me to resurface my rotors but from previous experiences I noticed side effects from that. So basically should I do it if it turns out that I have warped rotors?
Old Jan 6, 2005 | 12:13 PM
adithius's Avatar
If they are warped, just change them. You can get a pair of rotors for $50.
Old Jan 6, 2005 | 12:27 PM
Galo's Avatar
Maxima Pilot
All rotors should be resurfaced when installing new pads. If they are not warped, only a couple thousands of an inch will need to be removed, essentially, all you are doing is preparing he surface of the rotors to 'bed in' the new pads properly....
If you fear that, replace rotors...
Old Jan 6, 2005 | 03:40 PM
BM_00's Avatar
Well if you do have warped rotors, resurfacing doesnt mean it will "straighten out" the rotor since it depends how uneven they are. You got to measure the wear difference first and then decide.
In my opinion machine only if your rotors have deep grooves and have enough metal left. If the rotor's surface condition is good, I wouldnt bother.
I would recommend semi-metal pads instead of full since it will take less time for the rotors to wear out. Also, torquing your wheel nuts properly is important too.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
Colossus
Sep 9, 2015 05:46 AM
