03 auto, w/LSD STOCK !!!???
Old Jan 8, 2005 | 07:20 PM
Qmax03
Ok i dont know what to say, i never really did a burn out or anything but today at i light i decided to floor it against a wrx anyways i floored it and it jsut peeled out for a couple of second and kept peeling out for a good 10 feet, i came back around the block and to my amazement 2 tire tracks ALL the way 10 feet long, so i did it again in a parking lot same results over and over again no matter where i go both wheels spin, i tred in the rain as well and everythign,.. That is LSD correct ?
Old Jan 8, 2005 | 07:23 PM
Barc's Avatar
Not necessarily. Both wheels can / will spin if your on a surface that's basically the same under both tires. Easy way to check is to pour some water in front of one tire and none in front of the other, pull up onto the water, do a burn out, check results.
Edit:
Or you can turn the wheel to one side and do a burn out. That may be a simpler test. Or you can be brave and jack the car up on both sides and have someone grab one wheel then lightly tap the gas. OK, I've got plenty of other tests but that should be enough! lol
kklier's Avatar
LSD = lysergic acid diethylamide
HLSD = Helical Limited-Slip Differential
with HLSD you should get two tire tracks.
Old Jan 8, 2005 | 07:26 PM
Bluesbrekr's Avatar
Doctorate in Detailing
With an auto I believe it's traction control, not HLSD.
Old Jan 8, 2005 | 07:29 PM
Barc's Avatar
Limited slip hasn't been around as long as LSD, I'll give you that one! Just goes to show you what different meanings letters can have, huh? Let's all call it "posi" from now on, what'dya'say?! lol
upstatemax's Avatar
you will never get a burn out with the TC on though...
i know
Old Jan 8, 2005 | 07:30 PM
kklier's Avatar
doh, you are right the OP does not have any sort of HLSD, but he might have some LSD.
Old Jan 8, 2005 | 07:33 PM
Barc's Avatar
We can always ask him if he had any blotter paper or sugar cubes in the car. Maybe he just "saw" 2 tire tracks... and the pavement melting... and cobras! j/k! lol
Old Jan 8, 2005 | 07:37 PM
kklier's Avatar
Old Jan 8, 2005 | 07:43 PM
Qmax03
The car doent have traction control, yea ill do that 1 wet tire thing.
Old Jan 8, 2005 | 09:10 PM
mhadford's Avatar
I laughed, and laughed, then the dashboard melted before my eyes...
Old Jan 8, 2005 | 09:13 PM
mhadford's Avatar
As much fun as burnouts are, you could just match the transmission model number found on the firewall plaque behind the engine to the tranny model numbers published over and over on this board. Just search for LSD!
Old Jan 9, 2005 | 07:54 AM
BP's Avatar
BP
i don't think auto's had the option of HLSD.
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
jaydot901
Sep 29, 2015 01:18 PM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
