Video clip of my exhaust
Old Jan 9, 2005 | 02:06 PM
SoonerFan's Avatar
Cletus
UPDATED** Video clip of my exhaust
Ok here is a video clip I just made of my exhaust.
I have a y-pipe and just replaced the cat with a straight pipe. Love the sound...nice deep drone ..no weed eater sound
this is my first time with webspace and ftp servers...hopefully the link works.
enjoy
**UPDATE**
I just added a new video. It has action shots from inside and outside the car. For those that saw the first video, you can tell that the sound is louder and deeper under load and WOT.
ENJOY
http://members.***.net/jttaylor155/C...st%20Small.wmv
Old Jan 9, 2005 | 02:11 PM
Puppetmaster's Avatar
It works... sounds good too... although I was kinda hoping for some "action shots" of ya speeding up and down past the speed traps on 50 or Fairfax County Parkway...
Old Jan 9, 2005 | 02:12 PM
Ben's Avatar
Ben
I like the sound. I'd like to hear it in a couple more situations. Maybe highway and some more reving. Notice any power dif?
Old Jan 9, 2005 | 02:15 PM
SoonerFan's Avatar
Cletus
i plan on doing some driving shots soon. it actually sounds nicer under load.
i will do inside and outside the car cruising and inside and outside the car WOT
Old Jan 9, 2005 | 02:17 PM
SoonerFan's Avatar
Cletus
yes i can
low end is ALOT better. before i had to be over 3K rpm to really pull. now it starts to pull and 2K. now even with half throttle it just takes off!!
Old Jan 9, 2005 | 02:40 PM
ibag8rfan's Avatar
that's with just a Y-Pipe and test pipe? Sounds more like an aftermarket cat-back.
Props
Old Jan 9, 2005 | 02:56 PM
S00NR1's Avatar
OU > *
Aight Jason, you need to drive down to Norman and help me install that exact same setup.
Old Jan 9, 2005 | 03:01 PM
SoonerFan's Avatar
Cletus
Props
yup..y-pipe, test pipe, stock muffler
Old Jan 9, 2005 | 03:02 PM
SoonerFan's Avatar
Cletus
im on my way
Old Jan 9, 2005 | 03:09 PM
Zero Deuce SE's Avatar
Sounds nice.
Old Jan 9, 2005 | 03:15 PM
Barc's Avatar
It does, indeed, sound nice. I was thinking of going aftermarket y-pipe to stock cat to custom cat back to stock muffler, basically eliminating the resonator but upping the stock tubing size. But after hearing that, I think I will have to order a resonator as well. Your's is about where I want my sound level to be.
Old Jan 9, 2005 | 05:28 PM
whtslprmax's Avatar
Sounds real nice. Do you have a stock B-Pipe? Also, if not are you runnin a resonator on ? I've got a y-pipe, custom 2.5" into a stock can and am trying to decide if I want to remove the 18" Magnaflow Resonator I have on my B-Pipe...I want to hear you rev it.
Old Jan 9, 2005 | 05:30 PM
SoonerFan's Avatar
Cletus
yes i have the resonator....from the straight pipe back it is stock. resonator and muffler
Old Jan 9, 2005 | 05:56 PM
jesse's Avatar
VTEC This!
pretty cool, gives it a g35/350z type sound, with the stock look
Old Jan 9, 2005 | 05:58 PM
SoonerFan's Avatar
Cletus
thats what i thought too. and people that have heard it in person said the same thing
Old Jan 9, 2005 | 06:01 PM
S00NR1's Avatar
OU > *
Hey Jason, is your test pipe a certain brand or is it like those that are on ebay for 30 bucks? If so, is there a difference and where can I find a reputable one?
Old Jan 9, 2005 | 06:03 PM
SoonerFan's Avatar
Cletus
from ebay...got it from my roomate..was on his SE-R
Old Jan 9, 2005 | 06:05 PM
S00NR1's Avatar
OU > *
Something like this?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33629
Old Jan 9, 2005 | 06:07 PM
SoonerFan's Avatar
Cletus
mine isnt as fancy..looks like normal exhaust pipe with flanges
Old Jan 9, 2005 | 08:18 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Hey, sounds good man
Old Jan 9, 2005 | 08:43 PM
NOCturnalI30's Avatar
did u just jack up the car and unbolt it urself and put it back together was there anything special involved with the install???????????
Old Jan 10, 2005 | 02:10 AM
SoonerFan's Avatar
Cletus
did it myself.
jacked it up, removed the cat, and installed the pipe. i used two gaskets on each side to ensure i wouldnt have a leak
Old Jan 10, 2005 | 03:59 AM
jmal's Avatar
Originally Posted by soonerfan
yes i can
My thoughts exactly on the 3k...I think I'm going your route!
Old Jan 10, 2005 | 10:00 AM
brettb's Avatar
O'rly
Real nice sound.
Old Jan 10, 2005 | 02:09 PM
dbrooks's Avatar
enjoy
http://members.***.net/jttaylor155/C...%20Exhaust.wmv
So uhh, how does it affect emissions since you replaced the Cat with a straight pipe?
Old Jan 10, 2005 | 03:17 PM
MaximaSe2002's Avatar
sounds good almost like mine but yours is a bit louder. i also have the cattman y and muffler but i fabricated my own b-pipe out of 2.5" stainless steal the sound of our cars is real similar
Old Jan 11, 2005 | 01:30 PM
SoonerFan's Avatar
Cletus
In order to reduce emissions, modern car engines carefully control the amount of fuel they burn. They try to keep the air-to-fuel ratio very close to the stoichiometric point, which is the calculated ideal ratio of air to fuel. At this ratio, all of the fuel will be burned using all of the oxygen in the air. This significantly reduces carbon monoxide, VOCs and NOx molecules (the gases that a three-way catalytic converter is also designed to reduce.)
Bottom line...as long as your car is serviced, you take care of it, and use the proper fuel...the emissions are neglible. (a lot less then your city bus that is supposed to reduce pollution )
disclaimer - you will fail an emmisions test if your state or county require it. OK does not
Old Jan 11, 2005 | 05:23 PM
whtslprmax's Avatar
You convinced me...ordered one today...I'm tagged in OK an had forgotten all about the "no inspection." Thanks for the insight bro.
Old Jan 11, 2005 | 09:23 PM
dr_redonkulous's Avatar
disclaimer - you will fail an emmisions test if your state or county require it. OK does not [/QUOTE]
anyone know if colorado checks for this?
Old Jan 12, 2005 | 12:04 AM
S00NR1's Avatar
OU > *
Alright, another Oklahoma org member! Let us know how your setup sounds.
Old Jan 12, 2005 | 04:19 AM
Ben's Avatar
Ben
anyone know if colorado checks for this?[/QUOTE]
Yes, they do. I used to live in boulder and they are fairly strict on emissions.
Old Jan 12, 2005 | 05:11 AM
kcowden's Avatar
Sounds good... how are you sneaking by on the emissions inspections with the straight pipe??? I lived in VA for many years and fell victim to the emissions test a few times.
Old Jan 12, 2005 | 08:04 AM
S00NR1's Avatar
OU > *
Soonerfan's vehicle is tagged in Oklahoma. Oklahoma has no vehicle inspections. Therefore, Soonerfan can get by with having the straight pipe.
Old Jan 12, 2005 | 08:18 AM
alicious's Avatar
the org...not what it was
Sooner - after hearing that sound this (and the y-pipe) are going to be my next mods. Thanks for posting, exhaust note is sweet.
Old Jan 12, 2005 | 09:17 AM
char's Avatar
I heard that if you sub in a straight pipe for your cat, a foul odor emanates from the exhaust. Something that smells like rotten eggs. There are many posts that i have read that can attest to this at mx6.com.
Does this apply to our Max's?
Old Jan 12, 2005 | 01:07 PM
SoonerFan's Avatar
Cletus
have you ever gotten your car inspected? do you have an inspection sticker on your car?
Old Jan 12, 2005 | 01:08 PM
SoonerFan's Avatar
Cletus
plus no front tag and darker tint
Old Jan 12, 2005 | 01:10 PM
SoonerFan's Avatar
Cletus
that smell is from the cat itself when it goes bad. its the particles inside. the smell is not from the exhaust that isnt being cleaned by the cat. i have NO SMELL
Old Jan 12, 2005 | 01:30 PM
Ceasars Chariot's Avatar
Old Maxima Legend
hey that sounds good
Old Jan 12, 2005 | 04:31 PM
dmitry82's Avatar
Hey, sounds good! I like the sound!
