Manual Radiator Fan?
Old Jan 11, 2005 | 03:47 PM
I30swimmer's Avatar
has anyone done the manual radiator fan mod on a 2000-2001? i have looked at both the 4th gen and the 5.5 gen version. but i cant find the Pin number to use from the ECU?
are the 2000-2001 ECUs the same as the 4th gen? totally different ? or the same as the 5.5 gen?
Old Jan 11, 2005 | 04:10 PM
Hind
I too would like to know this. I live in florida and summer is on its way (its summer 100% in FL) and when I go to the races, this would be a functional benifical mod.
I30swimmer's Avatar
it seems like no-body knows.. im gonna go look outside right now..
Old Jan 11, 2005 | 04:24 PM
paralyse's Avatar
I Miss My Maxima
Not sure why anyone would want to do this to a Maxima. It would be more beneficial to remove the drive belt from your A/C compressor and use a shortened belt, and then just turn the a/c switch on, which forces the radiator fan to run. Haven't tried that, though.
If it's like most other cars you need to run a wire between the two outer posts of the rad. fan relay with a SPST (NO or normally open) toggle switch in the middle? or just find the +12v power lead going to the fan motor and wire it direct to battery + terminal.
Old Jan 11, 2005 | 04:40 PM
I30swimmer's Avatar
well first off.. i know for a fact that your wrong.. the rad fan always has a power supply. it is simply switched on by a relay. which supplies a ground.. therefor compleating the circuit.
can someone tell me where the ecm is located. cause that would help out a great deal
Old Jan 11, 2005 | 06:22 PM
I30swimmer's Avatar
bhhhhuuuuummmmmppppp
Old Jan 11, 2005 | 07:39 PM
pbb's Avatar
pbb
what u can do on most cars is if u can find the sensor that kicks the fan on and just jump the wirest. I'll see if i can find it sometime, unless someone knows where it is. Its usualy a little sensor with two wires coming out of it that is connected somewhere to a radiator hose.
Old Jan 11, 2005 | 08:20 PM
I30swimmer's Avatar
i dont know if that would work either.. simply because that would only send a tempeture signal back to the ecu.
If anyone has the hanyes manual for a 2000-2001 can you please tell me what color wire is used to connect the Radiator fan (high speed) to the ECU? ussually it has initials like LG / LG/R Y/W stuff like that.. and the high speed pin would have an H at the end of its initials rather than a L
Old Jan 11, 2005 | 09:15 PM
MaximaVQ97's Avatar
I did it to my car, ill look up on what wires i tapped into the ECM cooling fan high is #34 (LG) and cooling fan low is #35 (BR/R)... make sure you have a DPDT switch or else it WILL NOT WORK... i use this only for track purposes, i dont know about everyday stuff ... i think the maximas cooling fans turn on fine the way they are!!
if you have anymore questions feel free to let me know!!
-Anthony
Old Jan 12, 2005 | 12:48 PM
I30swimmer's Avatar
keep the info comming.. and pics of the correct wire comming
Old Jan 12, 2005 | 04:50 PM
I30swimmer's Avatar
WE HAVE ACTION.. i finished the mod tonight.. have to say it pumps air.. HARD .. best part is the sound.. sounds like a supercharger under the hood. WOOT WOOT
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
