Just Completed Hyperground....thoughts
Old Jan 12, 2005 | 09:57 PM
S00NR1's Avatar
OU > *
Spent nearly the entire day completing this project due to rounding up of materials and other unforseen issues. However, I just took it out for a spin and I have a couple of observations.
On engine response - I don't seem to feel much difference here but for some reason it seems like the transmission is shifting a bit quicker and smoother....interesting. Idle is a bit lower (now just below 1k rpm) and smoother as well.
On others - One thing I noticed is that the headlights and fogs are definitely a bit brighter and it also seems like the radio for some reason sounds a bit "crisper". Also, not sure if this is really logical, but the brakes feel quite a bit more responsive as well.
Overall, I found this to be a very worthwhile endeavor and thanks to Irish for a SWEET how-to writeup....couldn't have done this without him.
Expenses:
25ft of 6 gauge Borg Warner battery cable (O'Reillys) - 1.49
12 6 gauge copper circular lugs (end caps - O'Reillys) - 11.88
4 6 gauge copper circular lugs "" (Autozone) - 3.98
New bolts, nuts, and washers ~ 4.00
Total ~ $22
Old Jan 12, 2005 | 10:32 PM
crispykid717's Avatar
Bigger than Jesus
I noticed a difference in throttle response (quicker) but not with the headlights or brakes though. I was hoping it would take away the engine noise from my speakers but it didn't. I agree, it was a very easy and beneficial mod to do.
Old Jan 12, 2005 | 10:52 PM
sooner02r1's Avatar
I'm glad you're happy with it. It would've saved a lot of time if we had discovered Van's secret crimping method earlier.
Old Jan 13, 2005 | 09:47 AM
S00NR1's Avatar
OU > *
Ya, the soldering was definitely the most time consuming part of this procedure...and it didn't even work. I am glad Van made me look stupid by showing us that way to crimp, so that I didn't spend the whole day just trying to solder the wires.
Old Jan 13, 2005 | 09:53 AM
2k2kev's Avatar
It's chrome alright...
"van's crimping method" ..............
Old Jan 13, 2005 | 09:58 AM
S00NR1's Avatar
OU > *
Lol, as Adam and I were messing with the solder and not getting anywhere, Van walked up with his hammer, put the wire and copper endcap to the ground, and just flattened it right onto the wire -- worked like a charm, lol.
Old Jan 13, 2005 | 10:02 AM
Jeff92se's Avatar
I'm needing a caw
I soldered and crimped. Since those big lugs are hard to crimp, I put the flux on the wire, then put the wire into the lug. Then where the two crimp ends meet, I used a hammer and large screwdriver to crimp the wire down. Then heated the lug/wire and flowed the solder into the area. Very easy. Don't forget to slip on the heat shrink of before.
Old Jan 13, 2005 | 10:07 AM
S00NR1's Avatar
OU > *
Well, I didn't use any heat shrink. Just put electrical tape around the exposed areas of wire near the lug.
Old Jan 13, 2005 | 10:09 AM
E55AMG2's Avatar
Wat
Go get some dyno graphs to see what it did to the power delivery.
Old Jan 13, 2005 | 10:10 AM
Jeff92se's Avatar
I'm needing a caw
Eh, the thing is the tape will unravel after awhile.
Old Jan 13, 2005 | 10:13 AM
S00NR1's Avatar
OU > *
I plan to, but considering there are zero places that dyno around here, I will have to wait until I get back down to Dallas in a couple weeks.
Old Jan 13, 2005 | 02:33 PM
S00NR1's Avatar
OU > *
After getting to drive for an extended amount of time for the first time post-install, I noticed that my car is now idling down around 600rpm and it barely even seems as if the car is running.
Old Jan 13, 2005 | 02:39 PM
stephenlc's Avatar
I think i need a grounding kit. Everytime I step on the gas at night my lights get dimmer.
Old Jan 13, 2005 | 03:06 PM
SoonerFan's Avatar
Cletus
i love mine..quicker start-up, smoother idle, better throttle response, windows roll up quicker, and lights are brighter
Old Jan 13, 2005 | 04:00 PM
irish44j's Avatar
retired moderator
all of you oklahoma boys are by my hyperground writeup
Old Jan 13, 2005 | 04:07 PM
Epacy's Avatar
Unsuccesful STL Coordinator
It would be funny if it was true!
Old Jan 13, 2005 | 04:18 PM
irish44j's Avatar
retired moderator
if what was true?
Old Jan 13, 2005 | 04:31 PM
S00NR1's Avatar
OU > *
That's exactly what I asked him.
Old Jan 13, 2005 | 07:20 PM
ZIPPIN's Avatar
Mauja He Mauja
or may be all of it is in our minds ??????
Old Jan 14, 2005 | 02:47 PM
irish44j's Avatar
retired moderator
by the way...why do all of you okie guys all have "sooner" in your name?
I don't see any of the Va. guys with "Cavalier" or "Hokie" in their screenname or any of the SoCal guys with "Trojan" in their name...
is there not any other "identity" that someone from Oklahoma can have? j/k
Old Jan 14, 2005 | 02:58 PM
Gsilk's Avatar
Reported
no kidding. dedication i suppose.
Old Jan 15, 2005 | 11:09 AM
SoonerFan's Avatar
Cletus
we are just real fans..we support our team all the time. we dont just throw on an OU hot when they are doing well and call ourselves a fan.
and the sooners are part of our identity..that happens when you have one of the best football schools in history
josh...ill change my name to JWICSFAN
Old Jan 15, 2005 | 11:41 AM
xlcrew's Avatar
I’m Back
well i'm a okie and i don't have sooners in my name, although i am diehard fan
Old Jan 15, 2005 | 03:34 PM
irish44j's Avatar
retired moderator
just wondering...I already knew what Jason was gonna say... heard it a million times. If I was "Patriotfan" (for my school) everyone would think I was a New England fan....
Old Jan 15, 2005 | 04:09 PM
dizmax96's Avatar
what size should i make my hyper ground wires out of? 6 or 8 gauge? should it be all copper wires? not sure what ill be able to find at autozone.
Old Jan 15, 2005 | 04:35 PM
S00NR1's Avatar
OU > *
I used 6 gauge wire.
Old Jan 15, 2005 | 04:56 PM
joeyd's Avatar
wheres the write up for this?
Old Jan 15, 2005 | 05:44 PM
S00NR1's Avatar
OU > *
Go to page 16 of Irish44j's Car Domain page. You will see it there and it is extremely helpful.
Old Jan 16, 2005 | 12:04 AM
whazzzzuup's Avatar
Chiming in a little late...I don't have "Sooner" in my name either.
Van
Old Jan 16, 2005 | 02:08 AM
joebangaa's Avatar
anyone have a writeup for a 5.5 gen? or is it the same when you take off the cover..
maybe i'll do this if i ever get around to doing the big 3
Old Jan 16, 2005 | 06:14 AM
ICELANDIC MAX's Avatar
contemplating about this one too- anyone with 5.5 gen write-up?
Old Jan 16, 2005 | 06:24 AM
pruizgarcia's Avatar
Here is a write-up for the 5th Gen. My thanks to the author...
http://www.cardomain.com/memberpage/313259/10
Pedro
Old Jan 16, 2005 | 06:31 AM
thanks pedro
Old Jan 16, 2005 | 11:58 AM
theMax's Avatar
A vice works good also!
Old Jan 16, 2005 | 01:29 PM
NOCturnalI30's Avatar
I just finished mine today im gonna post pics latar on today did something different, i wanna see wat you guyz think
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
