Installing dde's question
Old Jan 13, 2005 | 01:53 PM
AKOGAN's Avatar
When you install the dde's, are you supposed to use the same sealer glue that you already have on the headlight edges or are you supposed to put new glue/sealant in there.
If new than what kind, and will you be able to heat it and reopen if needed?
Old Jan 13, 2005 | 03:00 PM
looslip's Avatar
Horra!!
If you mean the headlight casing itself then most of the times just reusing the sealant that is there will suffice. However, if you notice that there is condensation in the headlight you can use aquarium silcone glue to seal up the edges.
Old Jan 13, 2005 | 03:55 PM
danimsta's Avatar
yeah the sealent already for the headlight is good enough
i have opened my headlights twice and they are still fine, just make sure u heat it up good and seal it tight
Old Jan 13, 2005 | 07:21 PM
ZIPPIN's Avatar
Mauja He Mauja
or drive to indy. i will do them for you
Old Jan 13, 2005 | 07:27 PM
danimsta's Avatar
or nashville
and i can do them haha
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
