help this prob is driving me nuts
Old Jan 14, 2005 | 03:00 PM
bringda40z's Avatar
in my 2000 se with 50k I get a pining noise in the engine alomst a rattle and loss of power evey once in a while when i go above 2k rpm. It first started with code 0420... then the other day in the rain the car was running real bad and shaking. I brought it to the dealer and it threw codes 0420 1320 and 0301. When i bought the car the coils were alreadty replaced! any one else have this noise? will new coils solve this. I had the ecm reprogrammed and now the rattles back and the ses lights back on.
Old Jan 14, 2005 | 03:13 PM
bringda40z's Avatar
Also the car had the ping noise before it threw a coil code. Also the stealership said my plugs might need to be changed, but there 100k plugs. Could it be bad plugs causing the coil failure?
Old Jan 14, 2005 | 07:55 PM
reyrey's Avatar
could it be simply bad gas? I notice my 01 Max started to shake and ping slight;y when I used below 91 octane gas. Just a thought.
Old Jan 14, 2005 | 08:36 PM
Bensmax00's Avatar
hey man--if the ses light is back on with the same code-then the whole y-pie and precats have to be replaced-that is the next step in the bulletin--as for the spark plugs--if they are stock than yes they are platinum tipped and do not(usually) need to replaced untill 105k it all depens on how you drive
Old Jan 14, 2005 | 08:38 PM
Bensmax00's Avatar
oh forgot u should run high octane gas(chevron)--these vq30 motor are highly sensitive to bad fuel
Old Jan 14, 2005 | 10:31 PM
bringda40z's Avatar
i only use schell premium, there is no chevron near me
Old Jan 14, 2005 | 11:04 PM
E55AMG2's Avatar
Wat
Mobil and Chevron are the top two in overall fuel quality, use those whenever possible. Shell is a great alternative to when those are not available, and so is BP/Amoco. Anything else is just asking for trouble.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
