Daytime running lights stopped working
Old Jan 15, 2005 | 09:02 AM
JayBird265's Avatar
I have a Max 2001 SE and recently the daytime running lights have stopped working. On Auto the head lights are on, but no tail lights. On Full all seems to work fine. Any suggestions on what may need to be replaced ?
JayB
Old Jan 15, 2005 | 09:23 AM
E55AMG2's Avatar
Wat
for more help ask this question again in the canadian regional forum.
Old Jan 15, 2005 | 11:01 AM
TDotMax's Avatar
I don't know your description is not clear...On auto you will have DRL's in the day then everything will turn on at night. If this is not the case the first thing to check would be the DRL fuse.
Old Jan 15, 2005 | 05:01 PM
ibag8rfan's Avatar
are Canadian max's different? when mine are on AUTO the lights don't come on until it is dark enough.
Old Jan 15, 2005 | 06:10 PM
reyrey's Avatar
in some cases such as the use of Daytime Running Lights
Since 1991 The government has made it mandatory for automakers and dealers of import cars include day time running lights (DRL). the headlight comes on automatically when you start the car. Only the head;ights are on for improved visibility.
Old Jan 15, 2005 | 06:15 PM
Sammzway's Avatar
No canadian maximas are not different. What E55AMG is trying to say is, you should ask this same question in canadian regional forum as well because you might have more people giving you more solutions to your problem.
Old Jan 16, 2005 | 09:09 AM
TDotMax's Avatar
Once the E-brake is down, in the day the headlights will be on, but they are not bright. Then at night you have your regular setup....
Old Jan 16, 2005 | 01:17 PM
Y2k2maxse's Avatar
DRL do NOT activate the tailights so you will just get reduced brightness headlights all the time until it is dark auto will turn all the lights on.
Old Jan 17, 2005 | 05:54 AM
takkar's Avatar
The DRL uses your hugh beam and very low voltage. So if your high and low beam work...then it might be the DRL module that has failed. Although there is no TSB/recall on this, Nissan Canada knows of this and I would suggest you get it fixed asap before they start complaining that you are out of warranty.
Old Jan 17, 2005 | 07:33 AM
TDotMax's Avatar
Just re-wire to your fogs
Old Jan 18, 2005 | 05:09 PM
JayBird265's Avatar
Canadian Maxima is different
Thanks for advice so far. It is true the Canadian version of the Max is slightly different as the DRL are alway on. However, when on AUTO (which I leave on always) it appears that at night the head lights are on but the tail lights are not. I will also post on Canadian forum.
Old Oct 1, 2013 | 05:26 PM
rhonster's Avatar
where is the DRL Module on a 4th gen?
scratch, found it in front the passenger strut tower
Old Oct 1, 2013 | 05:30 PM
Fakie J Farkerton's Avatar
It's in Canada.
Old Oct 1, 2013 | 05:44 PM
TunerMaxima3000's Avatar
Passenger side in front of the Strut tower. Black rectangular box. Needs to be removed, open case, resolder the bad connections, reassemble.
Same location on almost every single Nissan product
Old Oct 1, 2013 | 06:07 PM
rhonster's Avatar
Great. found it. Sure beats under the dash hondas. We have a pullyard here, should get it for $5 or so. thanks.
Old Oct 2, 2013 | 06:06 AM
bad solders are an infamous problem for these modules, don't be shocked if you find the one you pull at the junkyard is also bad.
Old Apr 6, 2014 | 06:30 PM
rhonster's Avatar
Anyone needs a used DLM, i have one for sale.
Old Apr 6, 2014 | 06:56 PM
george__'s Avatar
check the solder on the module... Fixed my issue a year ago
Old Apr 6, 2014 | 07:15 PM
DennisMik's Avatar
It's good that you fixed your car. Read the dates on the posts, George.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
