Cold running bucking
Old Jan 21, 2005 | 08:42 AM
Progress's Avatar
It's business time.
Before the car is warm, usually when it is cold out and I just start driving I'm getting serious bucking in 1st-3rd gears.
For example: Release clutch pedal, then change gears to second and kind of coast with minimal throttle the car bucks like hell until I push the clutch pedal back in. When it is warm, there are no symptoms except the typical bucking. BTW, I have an updated MAF.
Old Jan 21, 2005 | 09:14 AM
spirilis's Avatar
That's typically the Fuel Cut problem. I'm surprised you don't see those symptoms in warm weather; you probably should. There's a TSB you can have done at a dealership (supposedly ~1/2 hour labor?) to reprogram the ECU to eliminate that below 1800 RPM I believe. I haven't had it done yet.
Old Jan 21, 2005 | 09:16 AM
spirilis's Avatar
Actually, on second thought, I find that this "bucking" is a little worse when the engine is cold than when it's warmed up. Even in 9F weather, if my engine is warmed up, it feels just like it does (bucking-wise) at 90F outside.
I have the original MAF, for comparison.
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I have and it still bucks, just not as bad.
However, now with the fuel-cut TSB during cold weather it chugs/dogs until you hit about 2500-2600 and then takes off.
Once warm, no problem.
Old Jan 21, 2005 | 09:43 AM
Progress's Avatar
It's business time.
Did they reflash the ECU when I had the MAF replaced nearly a year ago? Or did they just reset it do you think?
Old Jan 21, 2005 | 10:24 AM
IceY2K1's Avatar
Could be either...should say on the receipt or they can look it up for you if you call the dealer.
Old Jan 21, 2005 | 10:39 AM
Progress's Avatar
It's business time.
Thanks, Ice, I'll check it out. No sense in spending $50 if I won't notice a difference.
Old Jan 21, 2005 | 10:56 AM
IceY2K1's Avatar
Oh, you'll notice a difference, I'm just not sure it's better, just different.
Old Jan 21, 2005 | 12:24 PM
GreenSeMax's Avatar
I still have the fuel cut issue, no tsb was performed. I heard that most cars have shown a 3-4hp loss after the ecu is reflashed. any dealer can see if you have had the tsb performed, either through their records, or they can plug in a consult II and check to see if your ecm PN is current. I asked the previous owner of my car why he didn't have it done, as i owned it post-warranty, and he said he heard the same thing from the tech at the dealer, and decided against it. I haven't any dynos to proove it or disproove this, if someone does, please shed some light, thanks
Old May 20, 2008 | 07:46 AM
EVC1959's Avatar
Cold Running Bucking
While this is a little different, my daughter's Cherokee did the same thing. Our mechanic said it was a dirty intake manifold. He cleand it out and it ran fine since. Don't know if would be the same for a Max.
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
