Car got stuck in snow. Got out and noticed a puddle of yellow solvent on snow
Old Jan 22, 2005 | 12:30 PM
Ammi's Avatar
350 Detroit Muscle
After getting my car out of snow (going back and forth for 5 min), I saw a puddle of yellow solvent on snow. I was thinking it was coolant. I couldn't smell anything though. Any coolant hose underneeth the car that I could have possibly ruptured?
Old Jan 22, 2005 | 12:32 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
The only one under the radiator I might say. Check the reserve sometimes when the car is really hot and the reserve is too full it will get rid of some coolant...
Old Jan 22, 2005 | 12:35 PM
E55AMG2's Avatar
Wat
coolant = green not yellow. Stay away from the yellow snow.....
Old Jan 22, 2005 | 12:37 PM
BLUEMAX01SE's Avatar
Maybe Your Max Pee'd! That's What Happened To Mine When I Got Stuck In The Snow, My Max Freaked Out And Pee'd All Over The Place! J/k Bro! I Could Only Think Of It Being Coolant, But Our Max's Have Killer Cooling Systems And Can Handle Extreme High/low Temps, But With The Pressure Load You May Have Put On The Max Trying To Get Outta The Snow, Even That Should Not Have Damaged Anything- Was The Snow Really Frozen Or More Of A Wet Type Of Slushy Snow- Maybe You Hit An Iceberg Like The Titanic!
Old Jan 22, 2005 | 01:38 PM
Ammi's Avatar
350 Detroit Muscle
It was soft snow. It's probably my coolant and yes there's yellow coolant. Not all coolant is green. So I shouldn't worry about busted coolant hose or anything?
Old Jan 22, 2005 | 02:07 PM
Lontar1's Avatar
I was going to say that. There is a pink coolant from Prestone.. that's what I use in my car....
Old Jan 22, 2005 | 02:53 PM
BLKMAX005SPD's Avatar
it could be like greece or somthing that was on the bottom of the car...
yellow greece?
Old Jan 22, 2005 | 03:59 PM
E55AMG2's Avatar
Wat
If youre using aftermarket coolant, it could be yellow. OEM is green.
Old Jan 22, 2005 | 05:05 PM
pimpinmax's Avatar
rust rubbing against the snow?
Old Jan 22, 2005 | 05:10 PM
silvermax2k2's Avatar
How is the car driving? notice any changes? did you check all the fluid levels?
Old Jan 22, 2005 | 05:23 PM
kenny's Avatar
yellow greece?
I don't think the Greek members of the Org would like your comment
Old Jan 22, 2005 | 05:49 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
only thing i can think of that might get hit underneath the car with a yellowish fluid is brake fluid. its typically clear when new but turns more of a yellow, melted butter color as it ages. i would think that you would be able to notice something like that pretty quick but it did come to mind.
Old Jan 22, 2005 | 06:37 PM
Ammi's Avatar
350 Detroit Muscle
You saying I could have busted a brake line?
Maybe........ I can't see how rust can be that yellow though
I just parked the car in my garage because it was freakin -2. I'll check the fluid level tomorrow. I should go under the car and check for leaks but it's just too cold.
Old Jan 23, 2005 | 07:18 AM
NYC TAR's Avatar
just this morning I did two min of grinding in snow( got stuck). I notice the same thing too. yellowish big drop of that stuff in the snow
I wish I had a camera at that time.
Old Jan 23, 2005 | 09:05 AM
jo8243's Avatar
Don't eat the yellow snow, man.......
Old Jan 23, 2005 | 10:59 AM
Ammi's Avatar
350 Detroit Muscle
You are very helpful........
Old Jan 23, 2005 | 01:14 PM
Saucisse's Avatar
This is usually formed from snow touching the flexible part off the Y pipe or cat...kind of chemical reaction.....working in an Infinity/Nissan/Kia dealership and got alot of complains up here from customers regarding those yellowish thing in the snow during winter season.
Old Jan 23, 2005 | 02:53 PM
Ammi's Avatar
350 Detroit Muscle
Now it makes sense. Location of the stain on snow was very close to the cat. Thanks for the info!
Old Jan 23, 2005 | 03:51 PM
NYC TAR's Avatar
yea thanks for info too
I thought it be a rip in cv joint from all that spinning
gotto dump those potocrap and get some real A/S tire,
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 6, 2015 11:36 AM
Jcof88
Aug 3, 2015 10:43 PM
