I need help with CAI... ASAP!!!!!!!
How do you fit the K&N filter onto the pipe? The stupid fender cover in front of the wheel is making it biyatch to put the filter on... Not only that, the filter itself is a pain in the butt to put on the pipe. I know I drilled the right hole b/c I measured it with that paper that comes with the intructions!!!!!
Did anyone else have this problem? How did you compensate???
Here's what I did...
j/k - Sorry buddy, couldn't resist. I do hope you can get your issue straightened out 'cause it sux to have parts just hangin' off your car.
Re: Here's what I did...
Originally posted by RcticMax
I took a step back, counted to ten and proceeded to spank the monkey until it fit.
This sucks b/c I temporarily converted it into a hot air..
Kev where are you buddy? I know you have the CAI installed... How did you do it?
Re: Re: Here's what I did...
That's it...... Ima gonna robb you of your AE kit!!!!! J/K...
I'm so funny!
Originally posted by footemps
ooglie stock cold air system...
in your case that would be...
ooglie stock hot air system...
am i right? cuz that's what i see on the stickies
Just havin' some fun with ya, RBa. Tryin' to keep your post at the top of the board to help you with visibility.
You use the hose clamp to hold the filter onto the end of the tube.
Look at these pictures and take out the screws from the places if have noted. You'll have to shove the filter between the fender cover and attach it from there. Good luck...
http://wwwcsif.cs.ucdavis.edu/~chin/...iles/cai2.html
Re: I'll be back
Originally posted by Y2KevSE
I'll be back after dinner if you need help.
Kev.. Does your cone filter touch the fender covers?
How did you get the fuse box(driver's Side one) back into place like that?
Thanks!!!!
Place Racing Hot Air Intake Pic here!
PR HAI... hehehe.
And while we're on the subject... help the man figure out how to stick the fuse box back on with the tube there. Cause we couldn't figure it out for the life of us.
It may be ooglie but not stock...... It's a place racing hot air intake!!!!!!!
I guess I have to wait for Kev & others to wake up!!!!
Re: Re: I'll be back
Yes please hurry.. I do need help ASAP..
How did you get the fuse box(passenger Side one) back into place like that?
Thanks!!!!
Thanks!!!!
Still awake?
Did you go to sleep also?
Thanks!!!!
Nope, the filter doesn't touch the fender covers. Are you sure you cut the hole in the location specified by the template? Did you accidentally flip it upside-down?
The tube should go under the fuse box (on the driver's side). Just tighten the bolts and it'll move back into place. If you don't want the tube to rub against the fuse box, put weather striping in between.
Thanks!!!!
Re: Still awake?
Are you seriously going to sleep? I thought you never slept...
Dam... Maybe I did cut the wrong hole or maybe cattman screwed me and sent me the wrong one.... I dunno.. I'm kinda ****ed. Spent about 6 hrs installing it(Most of the time drilling), Broke 2 screw holes on the MAF, & couldn't get the filter to fit.. If I drilled the wrong hole, What can I do to fix it? Drill one more hole that overlaps?
And you're telling me that the driver's side fuse box goes next to the tube? I couldn't follow your pics. Your filter seems to be very close to the foglight... Mine is touching the top of the fender cover...
Re: Re: Still awake?
The driver side fuse box goes over the tube... here are some pics of that: http://wwwcsif.cs.ucdavis.edu/~chin/...iles/cai3.html
The filter should not be touching anything besides the tube.
maxfever1987
Nov 19, 2016 08:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
