install time for shocks
Old Jan 26, 2005 | 07:49 AM
ODB's Avatar
ODB
tire dealer wants to charge me 5.5 hours of labor to install KYB shocks (front & rear) ... is this reasonable? Thanks
Old Jan 26, 2005 | 07:59 AM
UGAd13's Avatar
No! Do it yourself and save the $. Here is one good write up: http://www.innerbean.com/housecor/strut_install.html
Old Jan 26, 2005 | 10:14 AM
BLUEMAX01SE's Avatar
whaaaaaaaaaaaaaaaaaat? 5.5 hrs!!!! are they going to be sleeping for the first 2.5 hrs? when i had my install done (springs/shocks) it only took about 2 hours max, but i went to a very professional shop here in chicago who work on suspensions daily (car boutique) good luck with the shop who is going to charge you for 5.5 hrs of labor! you should ask them is it even necessary to wear your pants when you bring them the car, that has to be the worse case of rape i've ever heard of! i wonder how many hours they charge to actually change a tire? you may have to leave the car overnight or something!
Old Jan 26, 2005 | 10:22 AM
mhadford's Avatar
Maybe a first time do-it-yourselfer would take 5.5 hours, if he only had the car's scissor jack and was pretty drunk.
With hoist, air tools, and some experience this should be a 2 hour job for a mechanic, MAX!
Old Jan 26, 2005 | 10:24 AM
Puppetmaster's Avatar
FASHIZL took approx. 1.5 hours when he did my struts/springs with a lift and air tools.... I also helped phenryiv1 do a complete swap of his I30 suspension in less than 2.5 hours with a spring compressor, garage jack, and 4 jack stands....
In other words... I have to call on 5.5 hrs...
Old Jan 26, 2005 | 10:32 AM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
It took me 4 hours by myself. Borrow some tools and do it yourself. Like UGAd13 said, look at housecor's site. It's what I used
Old Jan 26, 2005 | 10:39 AM
BRAN808's Avatar
I have about as much mechanical experience as the dog right above this post, and it still only took me like 3.5 hours to do it by myself! I'd say try it yourself, and if you still feel sketchy, and don't want to try it yourself, look elsewhere. That's WAAAAAAAAAAAAAYYYYY too much.
Old Jan 26, 2005 | 02:56 PM
Triple8Sol's Avatar
I miss the .org!
No way. Either do it yourself or have it done at a shop. Shouldn't take them more than 1-2 hrs with their lift and spring compressor machine.
Old Jan 26, 2005 | 03:45 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Last suspension I did on a 4th gen, which is similar- took me bout a hour and half to do. Due to a stuck bolt on the rear suspension that was stripped out. 5.5 hours at around 90-100 bux a hour is alot of $$$ to just install shocks !
Old Jan 26, 2005 | 04:05 PM
CRBWS6's Avatar
While I agree that it isnt too hard of a DIY job, don't feel bad, I did end up having my springs/shocks done by a shop due to time constraints....but it only took them 1.5 hours and cost only $125.
My recommendation, take it to a motorsports shop that does import tuning.....much, much cheaper than ANY dealer. Good luck.
Old Jan 26, 2005 | 04:32 PM
Malecki2k3's Avatar
it takes about 2.5 hours
Old Jan 26, 2005 | 05:45 PM
A33 VQ30DEK's Avatar
i could do it in 1.5 hrs myself
done suspensions like 50 times
Old Jan 26, 2005 | 05:51 PM
theMax's Avatar
Yep professional shop should charge about 1-2 hours or $70-$150
I met a few nissan folks from my area and we did 2 maxima's in 3 hours.
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
