rear strut tower bar? anyone got it, any diff, where to get?
Old Jan 29, 2005 | 01:58 PM
super6's Avatar
if anyone has a rear strut tower bar i was woundering if you noticed any difference or anbsolutly nothing? is it worth the 40 or 50 buks, and where to get one? thanx
Old Jan 29, 2005 | 02:32 PM
Puppetmaster's Avatar
Someone else has a similar thread... might have some of the info ya need...
http://forums.maxima.org/showthread.php?t=374759
Old Jan 29, 2005 | 03:53 PM
bladerunr's Avatar
You might not need a RSTB seeing that you have a RSB. Someone who has both will need to chime in.
Old Jan 29, 2005 | 03:58 PM
GreenSeMax's Avatar
Yeah I got an ebay style I bought new in the box, but secondhand from an org member, and although some will say it does nothing it does have a slight effect. You notice it's stiffer, And the rear tracks better, in a sense follows the nose better. the greatest benefit is that it tightens up the rear, which causes oversteer, or in our case reduces the horrible understeer, this effect is felt the same as a rear sway bar, just not as much. I would recommend one, if you can sacrifice your trunk pass-through. You can always just take the center piece off and leave the ends on. Btw if you install it, be sure to remove the stock ring the goes around the upper mount, and distributes the pressure from the bolts, as the ends of the bar will replace this. Some people have left them on, and it prevents a flat mating of the bar ends to the tower top(the part of the unibody).
Old Jan 29, 2005 | 04:01 PM
GreenSeMax's Avatar
I have both, and when I installed them i did them a week apart, the tower brace first because it was snowy and it's easier, plus I wanted to see how it worked alone because everyone said it was worthless. I disagree, it makes a large difference, not quite that of the sway bar, but worth it, and of course both work the best, however still not curing the understeer. Next up is coilovers, perhaps i could play with those and fix some of that.
Old Jan 29, 2005 | 04:08 PM
spiromax's Avatar
Seoul Man
GreenSeMax, a couple of people over on my thread (http://forums.maxima.org/showthread.php?t=374759) have mentioned the eBay bars too, but I can't find any rear bars on eBay. Do you remember who you bought the bar from, or do you happen to know who the eBay seller was? I'm looking for an alternative to the Stillen.
Old Jan 29, 2005 | 04:23 PM
GreenSeMax's Avatar
i bought it from a guy on the org, maxgsr i think his name is. He bought it off ebay, i'll see if I can find it again, i found it a couple weeks ago just to see what it cost, it was like 40 i think .
Old Jan 29, 2005 | 04:28 PM
spiromax's Avatar
Seoul Man
Thanks, man. Any help you can offer would be greatly appreciated.
Old Jan 29, 2005 | 04:30 PM
GreenSeMax's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33591
That's it, and it's matches my courtesy front bar, minus the red ends but they're behind the carpet anyway.
Old Jan 29, 2005 | 04:33 PM
spiromax's Avatar
Seoul Man
I have no idea how I missed that. I searched "maxima rear strut bar" and every variation on that theme. Thanks for the link!
Old Jan 29, 2005 | 05:23 PM
FriscoMaxima's Avatar
in order not to let the Rear strut bar interfere with passing through the rear seats, just install it up-sude-down. It will have the same efect, yett get out of the way of the hole in back seat support. :-)
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
