Anyone have their oil light flicker quickly when they start up?
Old Feb 14, 2005 | 07:37 PM
TDotMax's Avatar
For some reason my car does this sometimes. Today I put in a Nissan oil filter instead as I heard some people have this prob from using aftermarket filters. Still no luck. Any ideas?
Old Feb 14, 2005 | 07:45 PM
Ammi's Avatar
350 Detroit Muscle
Mine does that too sometimes.
Old Feb 14, 2005 | 07:55 PM
2k1AEMaxRider's Avatar
The only time I have ever seen my oil light is when I'm starting the engine for the first time after I change the oil.
Old Feb 14, 2005 | 07:58 PM
Larrio's Avatar
The Definitive AE Master
mine always flickers during start up
Old Feb 14, 2005 | 08:11 PM
I30swimmer's Avatar
myn flickers too, you all think its normal?
Old Feb 14, 2005 | 08:55 PM
Larrio's Avatar
i just checked the oil level and its fine. It flickers for less than a second at start up, i don't think it should be an issue
Old Feb 14, 2005 | 09:54 PM
2000 Maximus's Avatar
Mine has done it before but its not all the time, I think when i first change the oil and when its cold out it usually happens but like all have said its really a short period like 1 second so i am not worried about it. - i have other things to worry about with this car!
Old Feb 15, 2005 | 03:17 AM
Cavez's Avatar
yeah...i had the same problem but I never figured it was a problem. I thought all cars did that?
Old Feb 15, 2005 | 05:03 AM
nailz420's Avatar
same happens here
Old Feb 15, 2005 | 05:14 AM
Zero Deuce SE's Avatar
No, mine never flickers.
Old Feb 15, 2005 | 05:18 AM
2MuchMAX4U's Avatar
I have 105K on mine and my oil light has flickered for some time now- I've even posted and no one knew why. I've changed oil, filters, etc.
Old Feb 15, 2005 | 10:19 AM
spirilis's Avatar
Yeah, frequently when I start up.
Old Feb 15, 2005 | 10:22 AM
chillywilly7g's Avatar
The oil light is the pressure sensor in your engine, it your engine oil pressure ( PSI ) fall below the pre-set minimum....( Which I'm not sure of? ) it will light up. When you start your car, hm let's say, in the morning, when you crank your engine, the pressure builds so It can move the oil around the engine. That's why the light flickers when you start it up....BUT if it starts flickering or stays on when you are driving, you better get off the road and stop your car. w/o any pressure, the oil can't go into the higher places of your engine, i.e., the intake valves, and other critical areas. Your engine is going to have a slow painful death.
So it's not really a thing to worry about. Mine does it as well, since I've gotten it. now with 42K miles on it, still does it in the mornings....light goes right off when she starts up.
Of course, you an always take it to the dealer and charge you an arm and leg and tell you that everything is ok. even though your car could be falling apart.....
Old Feb 15, 2005 | 10:44 AM
I hope my Tungsten Blue doesn't get what yours has. I'm at 37K miles right now.
Old Feb 15, 2005 | 01:37 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Mine does that...it stays on even longer when I'm a 1/4qt low and barely flickers when I'm a tad overfilled.
It's my ghetto oil check in the mornings, I always watch to see if I need to add a bit.
Old Feb 15, 2005 | 04:16 PM
panda_1's Avatar
mine does that all the time when i start up, no idea what it is though.
Old Feb 15, 2005 | 04:51 PM
Jaws's Avatar
My Tungsten Blue does it. You're doomed.
Old Feb 16, 2005 | 12:10 AM
LOL
nice one jaws, scare the poor guy out of his wits....
well to clarify charlie, the light flickers when I start up. once the engine runs on it's own, it turns right off. it's pretty normal. I used to have a 99 Altima w/ 89K miles and I had since 40K, always had the same flicker when I started the car up. See UNLESS it starts flickering while driving, now you have yourself a problem......but if not....don't sweat it, but if Jaws says your doomed....well, can't say much there.....
Old Feb 16, 2005 | 03:15 AM
LOL
No fear here. I have owned 5 different Nissans and none of them have ever done it. I have confidence in mine.
Old Feb 16, 2005 | 04:22 AM
TDotMax's Avatar
Ok so far yesterday and today no flicker. This is the longest period I went without a flicker. On monday I switched my oil filter to a OEM Nissan one. My mech at the dealer said its usually the aftermarket filters. And it seems like that maybe true so far.
Old Feb 16, 2005 | 04:59 AM
I'm wondering what oil and filters other people that have the flickering use.
Old Feb 16, 2005 | 10:06 AM
Jaws's Avatar
That's a very good question. I've been using the cheap OEM 15208-65F00 (had 10 of them to use up), but I'm on my last one, and have already bought the 15208-9E000. My car has 75k km on it, and it has only been doing it the last 15k km. I wonder if it will make a difference.
Old Feb 16, 2005 | 10:10 AM
AcerX's Avatar
As long as it doesn't flicker for longer than 5 seconds then your okay, found that out in a repair manual.
Old Feb 16, 2005 | 10:19 AM
Sizzo718's Avatar
This also happens to me on every other oil change. As mentioned by others, I also think that it's a lack oil pressure that's causing the light to flicker. I noticed that the flickering tends to disappear when more oil is added.
Old Feb 16, 2005 | 11:00 AM
What oil do you use, synthetic or conventional? I have used the 9E000 from my first oil change until now. I stocked up on them a couple of years ago.
Old Feb 16, 2005 | 11:02 AM
Jaws's Avatar
Mobil 1 5W30.
Old Feb 16, 2005 | 11:05 AM
Mobil 1 5W30.
I'm using Castrol GTX 5W30.
Old Feb 16, 2005 | 11:09 AM
IceY2K1's Avatar
9E000 w/Redline 10W-40.
The filter/anti-drainback valve, oil viscosity, temps, time since shutdown, etc. should all make a difference.
Old Feb 16, 2005 | 01:30 PM
spirilis's Avatar
Mobil 1 5W-30 with OEM Nissan Filter. It flickers on startup, stops immediately afterward.
Old Feb 16, 2005 | 01:33 PM
SkoorbMax's Avatar
Mine turns on briefly when I start the car. A second or two I'm talking about. If it's just after an oil change it stays on for maybe four seconds. Never "flickers" as in goes on/off/on or anything.
Old Feb 17, 2005 | 12:12 AM
yeah, I get that too when I change the oil, i've kept the filter oem and it's not a problem, I use Valvoline sinthetic. 5W-30. Haven't tried to use aftermarket yet, just out of couriousity I'll try it when I have to change my oil. I'll See, if any difference.
Old Feb 17, 2005 | 04:20 AM
TDotMax's Avatar
I lied still got the problem. But my mechanic changed it only because he had a 02 Max come in complaining and the pressure was really low. And it was the filter that corrected the problem. As for mine I still get roughly a few seconds only. He said my pressure is fine and I should not worry. He knows about this site. He said you guys should have your pressure checked to be safe.
Old Feb 17, 2005 | 04:58 AM
Are you using synthetic oil?
Old Feb 17, 2005 | 07:30 AM
NiZMo1o1's Avatar
hmm I put HIDS in my car and the passenger headlight always flicker when I start up.
Old Feb 17, 2005 | 08:05 AM
GBAUER's Avatar
I might be a little off-base here, but I don't think that has anything to do with your oil level. Check your windshield lugs. Also, if your Type R sticker is crooked, it might cause that as well.
Old Feb 17, 2005 | 08:10 AM
His Xenon may be a tad low.
Old Feb 19, 2005 | 06:51 AM
TDotMax's Avatar
No, using regular oil when I go in for changes.
Old Feb 19, 2005 | 06:55 AM
2MuchMAX4U's Avatar
I tried different oil Moble 1 syntec-> Castrol High Milage-> back to Moble 1 and tried a different filters from Mighty brand filter-> OEM brand... still flickers
Old Feb 19, 2005 | 01:08 PM
zourtney's Avatar
Mine will flicker too sometimes, only 1-2 seconds after startup. It usually happens when I run into the store for a few minutes and come back. Figure it's because the oil hasnt drained to the pan yet. Also, it seems to do it more when I'm needing an oil change -- probably about 1/2 quart low or something.
Old Feb 19, 2005 | 10:26 PM
Charliejag's Avatar
Mine does it most of the time. Say what you will, but I am not concerned at all.
