I think I broke my car tonight :(
Old Feb 15, 2005 | 05:43 PM
Mass_Media's Avatar
Mass_Media™
so I am going to see my friend at the mall and I haven't driven my car all day because it has been snowing....so anyway I am going to start my car and I start it but it won't start.....the starter just keeps going my car won't fire up....so finally after about 5min it starts but there is this thick white smoke is coming from my exhaust pipe....and it is running fine after that....is this something I should be worried about? Thanks for the help
Old Feb 15, 2005 | 05:57 PM
RacertilTheEnd's Avatar
I do not think there is anything wrong with your car per say, if I am correct, the reviews of the 5th gen maximas said that it had problems with cold starts, but nothing to worry about. As for the thick white smoke, it may have just been steam.
bert's Avatar
If I put money on it, it sounds like the starter ans specifically the starter solenoid. If you say that the starter was turning over but was not engaging the flywheel, the soleniod or it's relay is just about the only thing it can be.
As for the smoke I wouldn't worry too much about it. Chances are that you got some oil in the cylinders with all that cranking and it just burnt off. If it keeps doing it then you may have a problem. A few rules to remember:
- blue-white smoke: burning oil, not a big problem.
- black smoke: running too rich, not a big problem.
- white smoke (sweet smelling): coolant is getting in to the system: head gasket, cracked block... not not a big problem!
Old Feb 15, 2005 | 06:16 PM
Mass_Media's Avatar
Mass_Media™
Smelt kinda like burning plastic......
Old Feb 15, 2005 | 06:17 PM
Mass_Media's Avatar
Mass_Media™
ok I won't worry about to much if it happens again I am going to take it to someone
Old Feb 15, 2005 | 07:47 PM
bert's Avatar
Burning plastic?
Before you go anywhere, open the hood and take a look at the alignment of the main belt (alternator, main crank pulley, A/C, etc...). Compare the the alignment of the main crank pulley (way down at the bottom) to the tentioner. Everything should be in a straight line, a very straight line. Look at the main belt and make sure that it's not touching the power streering belt.
2 months ago my main crank pulley cracked, forcing the main belt to rub with power steering belt. When I started it that morning it cranked once, stalled for 2-3 seconds and then cranked again and started. I had never seen that before. There was a distinct smell of burning rubber. Tooling down the highway doing 75, the battery light and hand brake comes on, traditional "your alternator is dead" sign. Well it wasn't the alternator. The main belt and the power steerning belt had rubbed so much that the main belt broke and there was only 1/3 left of the power steering belt!
Old Feb 16, 2005 | 07:37 AM
Mass_Media's Avatar
Mass_Media™
Burning plastic?
Everything seems to be working fine I just looked at it a couple minutes ago and it looked all straight the belt wasn't touching anything....that I could see...thanks for the help, a friend told me it could also be vapor lock but he didn't know where the burning plastic was coming from....if my it was a belt or something like that it would keep smelling like that right? I haven't smelt anything since last night so....thanks for the help though it really freaked me out when it happened
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
bassmann
Aug 3, 2015 07:53 PM
