cylinder misfire
Old Feb 15, 2005 | 06:22 PM
maximakidd00's Avatar
cylinder misfire
hey guys, i have a little bit of a problem... my car started shaking recently when it was a low speeds/idle in gear. the next morning i saw that the SES light came on, so I went to autozone to get the code pulled, and the guy said that cylinder 5 is misfiring. is there any way that I can fix it easily? like what could cause this. and which one is cylinder five. i tried searching the net and the org for stuff about it but didnt come up with anything. thanks in advance
Old Feb 15, 2005 | 06:50 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
sounds like you have a bad coil. 99,00 & early build 01 are notorious for a high failure rate on the coils. your best bet is to replace all 6 since more than likely one or more will fail in the near future. i will try to locate the diagram that shows the breakdown of the cylinders in case you want to replace the bad one. you can contact dave burnette @ town north nissan or jerryromenissan.com and type in MAXIMA for a promotional code. both end up being around 300 shipped for all 6.
Old Feb 15, 2005 | 07:39 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
coils went bad.... replace them and problem solved... I think we should do a class action lawsuit against Nissan fo rthat...my .02
Old Feb 15, 2005 | 07:41 PM
Trance Artur's Avatar
Order of cylinders:
1 3 5 Rear
2 4 6 Front
Old Mar 15, 2006 | 03:39 PM
Nomad's Avatar
same thing just happened to me 97k on the clock but stiil sometimes it works sometimes it doesn't will look for the best price to replace it . Still have a Q i got two codes 1320 and 0304. @nd is for coil 1at is ignition signal. Can you tell what causes what? maybe problem in wiring since coil still works time to time?
Old Mar 15, 2006 | 03:56 PM
Nomad's Avatar
Originally Posted by Trance Artur
Order of cylinders:
1 3 5 Rear
2 4 6 Front
I went on the website and found left or right? which side i need for 4th cylinder?
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
