Anyone have problems with...(y-pipe)
Old Feb 15, 2005 | 07:58 PM
Trance Artur's Avatar
...the center member and WSP y-pipe? I mean the y-pipe hitting the center member while going over small pot holes. The center memeber is the bar in the center and the engine sits on it.
Old Feb 15, 2005 | 08:43 PM
xlcrew's Avatar
I’m Back
no i haven't, i have had mine on for about a month, the only problem i got is that when i get wheel hop the pipe will hit the tunnel, only because my flex pipe is still rock hard, i like mine and the install was pretty easy
Old Feb 16, 2005 | 12:30 PM
Anyone else?
Old Feb 16, 2005 | 01:05 PM
Link112's Avatar
When my wheels break loose my y-pipe causes the b-pipe to hit the cross member. I ended up taking it off. When it did hit it would hits pretty hard. I looked under my car and I am very close to the part you are talking about, but it does not look like it is touching. Dallas was going to send me another brace, but I never showed up.
Old Feb 16, 2005 | 02:01 PM
HNDA ETR's Avatar
Still Here... IM me for more..
check to see if your motor mounts are sagging, missing, melting, etc... maybe that's causing you to lose clearance...
just a thought...
Old Feb 16, 2005 | 02:02 PM
kcowden's Avatar
Had same problem... took it off with no adverse effects. The support brace included with the pipe is useless IMO.
Old Feb 16, 2005 | 06:55 PM
just a thought...
I'm planning on replacing the rear motor mount, cause I'm sure that it needs to be replaced. Also does anyone know on difficult it it to replace the rear motor mount. I will be doing this at a shop myself, I will have all air tools available and lift
Old Feb 16, 2005 | 06:56 PM
Your thinking about the cross member, not the center member. The rear motor mount is connected to the center member.
Old Feb 16, 2005 | 07:17 PM
mdloops's Avatar
just a thought...
The problem is not the mounts. The problem is Dallas and Warpspeed. I tried to start a thread a while ago to organize everybody and make a complaint to him. Nobody wanted in although 10-15 people reported fitment problems with their products.
Basically you got screwed like the rest of us by buying anything from Dallas. I wish a mod would post a sticky on their fitment problems and save everybody money. I just put a crush in my midpipe because there is nothing you can do about it. BTW: Your flex section is not "still tight". IT will stay that way because the bends in the y-pipe are all f-ed up and it puts a great amount of pressure on the flex section.
Old Feb 16, 2005 | 07:21 PM
panda_1's Avatar
had mine on for bout 6 months no problems here.
Old Feb 16, 2005 | 10:42 PM
whazzzzuup's Avatar
Look at this thread:
http://forums.maxima.org/showthread.php?t=359995
Old Feb 16, 2005 | 10:51 PM
xlcrew's Avatar
I’m Back
i guess i got a good one, but i talked to wsp on monday had my pipe by friday, and had everything to put it on.it went in really easy and i have had no complaints, and i have checked it like 3 times since i put it in and it's fine. so i have no problem with them
lrb6805
Sep 30, 2015 08:12 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
