Cat-back Performace Gains
Old Feb 19, 2005 | 06:32 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I know this has been discussed many times. However, I am about to purchase a cat-back and would like to see verifiable results from people on whether their cat-back addition has added any gain. I am most likely going with Cattman. However, I would like to see results on all types.
Old Feb 19, 2005 | 10:19 PM
Charliejag's Avatar
I just got a Cattman and I love it. I noticed a small gain in power, but I didnt dyno it or anything. Cat-back systems are not the source of large gains by any means. When you replace both the intake and exhaust, the engine can 'breathe' with much less effort, leaving more power for the pavement. Stock headers, y-pipe, and cat with an aftermarket catt-back exhaust are not going to make too much more power. The real gains come from replacing the y and headers. The thing is, the gains from doing all youir exhaust components are greater than the sum of the parts.
Old Feb 19, 2005 | 10:31 PM
chris'smax's Avatar
On a NA car not anything noticable, just alot of noise that makes you think you are going faster
Old Feb 19, 2005 | 10:38 PM
Lytheum's Avatar
i have intake and exhaust and i was inching away from a 2000 or 2k1 i30 on the freeway today. i figure its the same car so we should be pretty even. wasnt really paying attention to speeds, but his front bumer was by my front door when he hit the brakes.
Old Feb 19, 2005 | 10:52 PM
Ammi's Avatar
350 Detroit Muscle
sound is deceiving
Old Feb 20, 2005 | 05:46 AM
03BlkSETE's Avatar
On a VQ35 you'll get a 5-7 HP increase with a catback with a straight through muffler. No has dyno'd a Frankencar car yet that I know of which has a chambered muffler. I'll see if I could find some thread with dyno comparisons.
Old Feb 20, 2005 | 06:10 AM
03BlkSETE's Avatar
VQ35 before and after catback dynos
OBX catback
http://forums.maxima.org/showthread....no+obx+catback
Greddy catback with RT cat
http://forums.maxima.org/showthread....reddy+dyno+cat
Old Feb 20, 2005 | 08:07 AM
joebangaa's Avatar
if anything just the b pipe should do the same thing, or almost the same thing as a catback
Old Feb 20, 2005 | 08:17 AM
chris'smax's Avatar
the gain is power is coming off the b pipe. On a NA maxima the stock muffler is more than sufficient. I say just get a b pipe and get a custom made 2.5 pipe to replace the rear section and weld the stock muffler up to it.
Old Feb 20, 2005 | 09:00 AM
joebangaa's Avatar
warpspeed b pipe doesn't attatch directly to the stock muffler? you have to fabricate a short 2.5 in pipe to lengthen the b pipe? i did not know this
Old Feb 20, 2005 | 09:35 AM
03BlkSETE's Avatar
How do you know that? Have you seen dyno's comparing just the b pipe to a full catback? Certainly the stock muffler flows well but I've yet to see any proof that the vast majority of the HP gains are found in the b pipe. If anyone has any hard evidence I would like to see it because my exhaust setup is a little loud the way it is.
Old Feb 20, 2005 | 10:04 AM
joebangaa's Avatar
if you were to get an aftermarket muffler on stock piping vs 2.5" b pipe w/ stock muffler, i'll bet the latter would have better gains
Old Feb 20, 2005 | 10:06 AM
mjg's Avatar
mjg
i had just the warp speed resonatorless b pipe for going with a full cattman cattback setup. Yea it did attach to the stock muffler, and yea it did next to nothing but make my car really noisy (in a bad way).
Old Feb 20, 2005 | 10:26 AM
chris'smax's Avatar
I am speaking from experience. i had a straight through muffler on a 2.5 inch b pipe and when i switched back to my stock muffler(without the rear section piping) i didn't notice any loss in performance. This was done with me running a supercharger w/ a 10psi pulley so the results would be more dramatic, therefore more noticable. I also have the WSP y pipe and it gives a nice growl at WOT. I switched back to the stock muffler because i too was sick of the noise. I hope this comparison helps .
Old Feb 20, 2005 | 10:29 AM
chris'smax's Avatar
you have to heat the rear section pipe up with a torch and bend it just slightly to bolt it up.
Old Feb 20, 2005 | 10:31 AM
joebangaa's Avatar
i think you mean before going to the full catback correct? maybe it was loud cuz you didn't get a resonator and if you do the ecu upgrade and get headers....the b pipe should make a difference
Old Feb 20, 2005 | 10:33 AM
chris'smax's Avatar
your car could be lighter due to the I30 having more options
Old Feb 20, 2005 | 10:57 AM
joebangaa's Avatar
i30's are heavy, especially if they have the touring package
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
Maxboy23
Sep 4, 2015 06:04 PM
