Just unplugged battery for 10 mins....bad
Old Feb 19, 2005 | 06:47 PM
Y2k2maxse's Avatar
I just unpligged the battery I was putting an amp in i only had it unplugged for 10 min...i go to drive the car to test the sound system and that stupid ECU is back to learn mode again!! I did a 0-60 clock with it like this you wont believe the result: 26.7 seconds. AS FAST AS I COULD GET IT TO ACCELERATE. I hate it when its like this. I just ordered a MAF sensor so hopefully i will feel A BIG difference after i install it.
Old Feb 19, 2005 | 06:54 PM
njmaxseltd's Avatar
0 - 60 in 26.7 seconds?
That car shouldn't be on the road, 18 wheelers accellerate faster then that.
Old Feb 19, 2005 | 07:16 PM
P. Samson's Avatar
How long a relearn and what kind of driving did you do before you did the "0 - 60 run"? You have a known MAF issue as well?
Old Feb 19, 2005 | 07:52 PM
Y2k2maxse's Avatar
i drove it about 20 miles before i did that run. last time i unplugged it it took 250-300 miles to fully back to normal....yes i am 90% sure i have a MAF problem thats why i ordered one. hopefully it'll be here ASAP i hate the car like this
Old Feb 19, 2005 | 08:13 PM
BRINKLEY's Avatar
I'm fixing to install my system in my car. I guess this will happen to me as well? How do you know the ECU is back to learn mode? And is there anything you have to do, just drive it as normal as possible or what? Aggggg......thats the only thing I don't like about reading these forums.... scare the chit out of me. lol At least I know ahead of time what is coming though.
Old Feb 19, 2005 | 08:16 PM
E55AMG2's Avatar
Wat
you got a civic, since when?
Old Feb 19, 2005 | 08:28 PM
Redstone's Avatar
Yeah 0 -60 in 26.7 seconds is a bit too long.
Old Feb 19, 2005 | 10:46 PM
P. Samson's Avatar
For the home mechanic disconnecting and reconnecting the battery can result in performance issues usually first noticed as an unstable/abnormal idle (even stall), and particularly if the car is driven hard prematurely (which is a no, no) before the relearn is completed. This is poorly explained in your owners manual under "Ready for inspection/maintenance test" but the procedure for the "relearn" is there. Notice the statement "ordinary usage". This is why the "relearn" can take quite awhile. If you read the requirements in the "readiness" procedure it could take quite a while to meet all the requirements of the procedure by "ordinary" driving if you didn't actually know them (or accomplish the stated procedure). The dealers of course have the Consult ll scan tool to accomplish a "quick learn", which at minimum will set the idle. Hopefully this may explain why, if you disconnect and reconnect the battery for any reason don't suddenly assume that you have a problem. The relearn can take awhile.
Old Feb 20, 2005 | 12:05 AM
BRINKLEY's Avatar
P., so what you are saying is unless I don't want to shell out no telling how much $$$$, there is nothing I can do but deal with the poor running and try to drive it as normal as I can, and not try overdriving it. How long before the reset or is it automatic when the battery is disconnected?
Old Feb 20, 2005 | 12:29 AM
FriscoMaxima's Avatar
mine does a 0-60 is 6.9 secs
Old Feb 20, 2005 | 09:10 AM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
that's salt on an open wound...not cool.
Old Feb 20, 2005 | 09:23 AM
adithius's Avatar
The car will relean after you have driven for 3 times for a good distance. I'm not sure how far. It will go away soon.
Old Feb 20, 2005 | 10:16 AM
CJLax's Avatar
Re learn pedal location
I had the same issue's recently. Disconnected the battery and my car ran like s%^t. Do a search and find the sequence learning for gas pedal, ecu relearn and idle air volume. I know it's here somewhere I don't have the option to do a search. I found the papers in the car and relearned these parameters and the car ran great again. I had my timing bumped up to 17 degrees and the car ran great till I disconnected the battery. I thought I lost this setting because just like you the car ran great and then after the fact like hell. I started chasing the problem and all you have to do is find theses relearn settings and your car will be back to normal. The relearn is something along the lines of; turn key to on position for 3sec pump gas pedal 5 times within 5 sec's; so on and so on. Hope this helps
Old Feb 20, 2005 | 10:23 AM
BRINKLEY's Avatar
found this on another forum, guess I'll use this one when I do my system unless someone else finds another one:
Warm up engine.
-Turn ignition switch “OFF” and wait at least 10 seconds.
-Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
-Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
-Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
-Fully release the accelerator pedal within 3 seconds after the MIL goes ON.
-Start engine and let it idle.
-Wait 20 seconds.
Old Feb 20, 2005 | 10:33 AM
CJLax's Avatar
Relearning programs
Thats it. There are three different ones posted for 2k2.
Old Feb 20, 2005 | 10:42 AM
spiromax's Avatar
Seoul Man
I had my battery disconnected for well over an hour while I installed my intake, and the MAF was totally disconnected during that time. When I hooked it all back up, the car was fine. My trip odometer and my radio presets were all gone, but the car definitely didn't take almost 30 seconds to reach 60mph.
This didn't just happen because your battery was disconnected for 10 mins.
Old Feb 20, 2005 | 10:50 AM
LA02MAX's Avatar
i disconnect my battery all the time, and the only thing that ever happens is that my tripometer and radio presets are all reset....you should have a car thats slower than a freakin civic just from unplugging your battery for a while
Old Feb 20, 2005 | 02:50 PM
dadiesel's Avatar
Warm up engine.
-Wait 20 seconds.
So this procedure works for reseting the 00-01' ecu's also?
Old Feb 21, 2005 | 11:34 AM
Puppetmaster's Avatar
Unplugged my battery once for 1.5 hours to install my intake... and then 3 hours for my y-pipe... and then once 24 hours for the heck of it (cuz I was gullible and believed the ECU reset myth)... never had any of the problems mentioned....
Old Feb 21, 2005 | 12:21 PM
rule da road's Avatar
When I installed my intake, i never unplugged the battery. Which i think affected my MAF. If u've changed ur maf, should the battery be unplugged during? Will a Nissan ECU reprogram fix this if it happens?
Old Feb 21, 2005 | 12:39 PM
ZeRo MaX's Avatar
After reading all these threads.. i'm a little "iffy" about disconnecting my battery at anytime :-/
is there an actual safe way of unplugging the battery?
Old Feb 21, 2005 | 01:13 PM
I30swimmer's Avatar
yeah unplug the NEGITIVE terminal, to the battery.. dont unplug the positive side. once you reconnect the negitive side the car should run PERFECTLY WITHOUT CODES.. yall are doing somthing wrong
Old Feb 21, 2005 | 02:16 PM
panda_1's Avatar
i ahve unplugged my car several times, without having this problem arise. good luck with it!
Old Feb 21, 2005 | 02:23 PM
takkar's Avatar
I disconnected my battery when I went on vacation for a month..came back..everything was back to normal except the radio resets...
Old Feb 21, 2005 | 03:36 PM
dadiesel's Avatar
Which terminal did you disconnect? Did you have ANY relearn at all?
Old Feb 21, 2005 | 03:51 PM
slvr2KSE5's Avatar
it doesnt matter which terminal you disconnect first. breaking the cricuit is the same either way.
ive had the battery out of both of mine for a couple hours. my blue 1 went 3 months with a dead as a door battery with no ill effects.
neither 1 showed any poor running symptoms at all.
Old Feb 21, 2005 | 06:57 PM
dadiesel's Avatar
So then the only reason ECU's "relearn" is when there is some other problem, such as with the MAF?
Old Feb 21, 2005 | 09:15 PM
Kevin's Avatar
nope, your car has a throttle cable, not throttle by wire, so if you try that all you will do is flood the engine.
Old Feb 21, 2005 | 09:20 PM
Charcoal95GXE's Avatar
My auto 4th gen goes 0-60 in 6.67 sseconds. Thats why im better than all of you. :-)
Old Feb 21, 2005 | 09:21 PM
whoa holy crap minus the guy with the vr-4
Old Feb 21, 2005 | 09:27 PM
Kevin's Avatar
not me, i got the best of both worlds.
Old Feb 22, 2005 | 07:26 AM
dadiesel's Avatar
Good to know .
Old Feb 22, 2005 | 11:59 AM
silversurfersg's Avatar
reset it again and for a bit longer, then give it a few drives. dont bother punchin it 0-60
Old Feb 22, 2005 | 12:15 PM
SkoorbMax's Avatar
Disconnected mine once for several hours and noticed zero change in driving when I plugged it back in. Maybe I'm numbed, senses-wise, but it definitely wasn't taking 26 seconds to reach 60.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
bigfrank
Oct 1, 2015 12:51 PM
