Parking Brake adjustment
Does anyone know how to adjust the parking brake? Currently, I can easily pull the brake all the way up. Rear brakes aren't more than 20k miles old. I want to make the brake secure and tight 1/2 way up.
WHAT MacGyver cant figire something out on his own??!?! NEBAR!!!!
hehe all jokes aside, For a 4th gen under the center console should be an adjustment nut. Its right under the boot and all you have to do is unbutton the boot and its right there. A 10mm deep socket should do the trick.
Originally Posted by I30swimmer
um what about if the parking brake is near the brake pedal..? i dont know why the I30s have to put it there
On the 2000 Maxima if you pull the e-brake lever all the way up you will see a small hole on the underside. It takes a 10mm deep socket to adjust it.
I recently replaced my rear pads and couldn't get the e-brakes back on. I ended up removing the center console before I found it.
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
