Rear Window Switch
Old Mar 6, 2005 | 03:45 PM
RP300zx's Avatar
Rear Window Switch
Rear Window switch is not working however the window can still be controlled by drivers panel. Does anyone know a quick fix or is it best to go ahead and order the whole new switch assembly?
Old Mar 6, 2005 | 07:35 PM
OutMaxxed's Avatar
go to pepboys.. i have that same problem with my front passenger. A friend of mine looked it up and said the switch runs about 22$. Its the part right under the plastic switch. (the one u use to push down on). The thing is ... i havent got it done yet..
Old Mar 6, 2005 | 09:06 PM
nyautostyle's Avatar
Have you checked to see if the plug might be out of the port?
Old Mar 6, 2005 | 11:55 PM
vsamoylov
how is that possible? plug out of port? if the drivers main control unit controls it? i say the switch is bad.
Old Mar 7, 2005 | 12:34 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I believe me means that the rear door window switch may be disconnected on the under side of the housing. May be worth checking prior to spending the money on a new switch.
Old Mar 7, 2005 | 07:29 AM
vsamoylov
and that is not possible cause then you wouldnt be able to open and close the window with the drivers sdie main switch. if it was disconected, you wouldnt get any power to the switch at all.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Feb 3, 2019 08:34 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
