Bought a High Flow cat today.
Old Mar 7, 2005 | 12:08 PM
RacertilTheEnd's Avatar
I bought a high flow cat today from ebay. It was cheap so I said what the hell. My question is. If I install it, will it affect my stock cat back exhaust? As in, do I need to worry about anything?
Old Mar 7, 2005 | 01:54 PM
ZIPPIN's Avatar
Mauja He Mauja
nopeeeeeeeeeee
Old Mar 7, 2005 | 06:39 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the only thing you need to worry about is emissions. if you have them in your area you will fail. the reason is the high flow cat you but is most likely a test pipe/straight pipe. they sell for cheap because they are not actual cats. there are a few high flow cats on ebay but they typically for over 100. alot of the so called high flow cats are just straight pipes.
Old Mar 7, 2005 | 08:12 PM
spiromax's Avatar
Seoul Man
First, do what sloppymax said and make sure it's actually a cat and not a straight pipe. If it IS a cat, then you should be fine for emissions, but you might want to keep your stock cat if nothing's wrong with it. A cheap "high flow cat" (if it really is a cat) might actually be more restrictive than the one Nissan put on the car from the factory.
Old Mar 7, 2005 | 09:41 PM
How will it be more restrictive?
Old Mar 8, 2005 | 12:29 AM
spiromax's Avatar
Seoul Man
I'm not saying that it WILL be more restrictive, I'm just saying that lots of cheap "high flow cats" are either simple straight pipes (not even a cat), or if they are cats, they're sometimes more restrictive than the stock cat (just because of bad design).
Old Mar 8, 2005 | 12:30 AM
spiromax's Avatar
Seoul Man
Post pics of the thing, both the outside of it and the inside of it if you can.
Old Mar 8, 2005 | 01:40 AM
FriscoMaxima's Avatar
i have a no-cat design and to tell you the truth, it made no difference at all
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
Team STILLEN
Aug 10, 2015 04:29 PM
