P0420 Code SOLUTIONS ARE HERE!
Old Mar 7, 2005 | 08:49 PM
Komax's Avatar
Since there are SOOOO many of these posts, I want to help out because I personally have killed this code and problem free.
If you get the P0420 code check these things:
1. you may need a new reprogramming which the dealers do for around 80 bucks.
2. if that doesn't help, you may need a new catalytic converter
3. if you get this some time after installing a y-pipe, the removal of the pre-cats are causing it
SOLUTIONS (correlating to the above issues):
1. go to dealer and reprogram
2. buy a high flow cat (i got mine from Random Tech and it works beautifully)
3. but an 02 simulator from www.o2simulator.com for $30
I went through all three things and the o2 simulator FINALLY killed this code. I have a y-pipe. I replaced the cat (thinking now, i really didn't have to do this one). After research, o2 simulator took care of it.
So, P0420 people, check the above. I can't think of any other reason why you should get that code.
Old Mar 7, 2005 | 09:06 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Random Tech cats have a life expectancy of bout year, after that they fall apart. OEM cat is fine, and its high flowing also. And I posted bout the P0420,P0430 fix using a simulator months and months ago. People need to start searching for answers instead of asking the same ole **** every day.
Old Mar 8, 2005 | 09:07 AM
Kevin's Avatar
can you tell me what dealer did the ECU reprogram for $80 ? I'm willin to pay them to do it for $80, my dealer is trying to charge $170
Old Mar 8, 2005 | 09:14 AM
Stardust's Avatar
F---ing Kangaroos
Old Mar 8, 2005 | 10:51 AM
Komax's Avatar
Most Nissan dealers will do it for $80. I got mine done at Route 46 Nissan in Totowa, NJ.
Somebody give BlackBird a cookie. JK.
Old Mar 11, 2005 | 03:04 PM
rule da road's Avatar
Same here, LI dealers are charging about $150 for an ECU reprogram. Highly considering not doing it although i have a new MAF, intake, and y-pipe. I also have po133, Heated Oxygen Sensor 1 Circuit Slow Response. Will an o2 simulator help, i dont even think i need to replace my o2. Where can i get one of these simulators?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
