VIAS and Mag-Lite Mod Today
Old Mar 10, 2005 | 12:54 PM
Komax's Avatar
Today, I decided to go ahead and try to do the VIAS repair since my car has 108,000 miles. Went to Home Depot and saw the Maglite and mount as well so I said what the heck and bought it. Maglite Mod went well...nothing really. BUT I STRIPPED A SCREW OFF THE VIAS!!!!! So disappointed that I couldn't do the repair...sounds so good too. Gotta see what I have to do to get that screw out.
One last thing. On my way out of the Clifton Home Depot, I see a 2002-2003 Max with missing headlights parked in the lot. I feel sorry for the 5.5 because when will this end?
Old Mar 10, 2005 | 01:30 PM
ChromeSE5's Avatar
impact driver i think. You hammer it while it unscrews the screw... but i dont know how rounded or broken your crew is... good luck. When i figured out how to fix the VIAS with jb weld, i was so freakin happy with the results that i had to tell everyone. Good luck.
Old Mar 10, 2005 | 01:40 PM
Anzioblack44's Avatar
im glad i dont live in Jersey... headlight theft is worse there than anywhere in the US
Old Mar 10, 2005 | 02:53 PM
frankd121's Avatar
Not to mention the high insurance rates....
I'm glad didn't say in NJ for school...
Old Mar 10, 2005 | 03:22 PM
TheBigDu's Avatar
Yeah, everybody just yuck it up.
Old Mar 10, 2005 | 03:42 PM
Nismo3112's Avatar
Custom User Title
What exactly is the Maglite Mod?
Old Mar 10, 2005 | 03:57 PM
TheBigDu's Avatar
http://forums.maxima.org/showthread.php?t=366783
I could be a newb calling a veteran a newb, but I'll spare you the satire.
Old Mar 10, 2005 | 06:32 PM
Omegasrk's Avatar
I stripped one of the screws off the VIAS when I was repairing it. If you have any bit of the screw head left, what I did was to use a locking vise grip plier like one of these:
http://www.sears.com/sr/javasr/produ...id=00945622000
Use the plier to grab onto the head and spin out the screw. It took some time, but I was able to remove the screw.
steve...
Old Mar 10, 2005 | 08:18 PM
Gears & Crosses's Avatar
Can anything be done to prevent the theft of these lights? An extra alarm maybe? Extra bracing?
Old Mar 10, 2005 | 09:08 PM
crispykid717's Avatar
Bigger than Jesus
Data Dots. adsf
Old Mar 11, 2005 | 04:40 AM
ZIPPIN's Avatar
Mauja He Mauja
steve...
i used a dremel and carved a head on the screw. try that and some WD40
Old Mar 11, 2005 | 01:42 PM
Komax's Avatar
Good news and good news...
Good news is that i got the dumb screw out. Went to Home Depot, bought a small drill bit, a screw extractor and a screw extractor hand wrench...all for $10. You drill a small hole in the center of the stuck screw. You screw in the screw extractor using a small screw extractor hand wrench. It's exactly like uncorking a wine bottle. Tada!!! And it unscrews right out!
The other good news. After 108,000 miles...my VIAS is in perfect shape! Go figure. No shakes, rattles or cheap effects. And I redline my car very often.
So, I'm all done for now...gonna wait for the underdrive pulley to come in...
Thanks to all who helped!
Oh, by the way, while I was at it, I too replaced the screws on the VIAS with a m6x1.00 20mm bolt and washers. For the future...
Old Mar 21, 2005 | 08:10 AM
ZIPPIN's Avatar
Mauja He Mauja
where can this JB weld be purchased??
Old Mar 21, 2005 | 10:04 AM
nicks79's Avatar
Fixed my VIAS yesterday. Wasn't that bad, but the cup was free loose about 3 millimiters on the perimeter, about 15 degrees loose. I used sharp chizel and hammered slightly the rod that holds the cup, to make it spread into the area where there is movement. No need For epoxy.
Those screws suck. Got one almost stripped. But then I gave it 20 minutes of Liquid wrench, and it did the job. Replacing them with something better is a must, if you plan to get in there again.
my $0.02
Old Mar 21, 2005 | 11:03 AM
rule da road's Avatar
I too stripped the heck out of those bolts. I pull real hard at least up to 5k but never go over. Wondering if theres really a need to get in there. Anyone notice low-mid range gains? Thanks for the tip Komax, $25 into new tools, i think i might just pay my mechanic to get in there.
Old Mar 21, 2005 | 11:37 AM
kclmax2k1's Avatar
what's the size of those bolts?
Old Mar 21, 2005 | 11:56 AM
Drewhos's Avatar
I m going to do the repair next weekend. Im going to try some needle nose visegrips. I hope it works
Old Mar 21, 2005 | 01:58 PM
maseo77's Avatar
How difficult is this fix? Could the average **** do this without any problems?
Old Mar 21, 2005 | 03:13 PM
Rayn4est's Avatar
I'm surprised no one has flipped out that you called it the mag light mod. I referred to the fire extinguisher "mod" (and I even used quotes) and I got flamed. "It's not a mod!", "I did the oil change mod". Mod, install, call it whatever you want, just don't be bone stock.
Old Mar 21, 2005 | 05:27 PM
unrealii's Avatar
I only have 43k on the clock and I haven't noticed any problems with the vais. But now you guys have me scared and I think I will go ahead and replace the screws during spring break
Old Mar 21, 2005 | 05:47 PM
irish44j's Avatar
retired moderator
join the club....
fire extinguisher mod (in trunk)
first aid kit mod (in trunk)
mag-lite mod (in car)
if you physically alter the car (i.e. by screwing in brackets or whatever) I consider it a mod....a small mod, but still a mod.
"mod" = "modification"
oil change is not a modification, it is maintenance
maglite is as much of a mod as clear corners or aftermarket light bulbs....a small mod
Old Mar 22, 2005 | 07:45 AM
Sammzway's Avatar
Can someone please answer this question? I'd also like to know.
Old Mar 22, 2005 | 10:35 AM
mhadford's Avatar
JB Weld can be bought at almost any hardware or automotive store. It's just a good grade of epoxy glue. If JB Weld isn't available, another brand of epoxy should work.
Old Mar 22, 2005 | 10:54 AM
Sammzway's Avatar
Thanks ..
salty318
Sep 28, 2015 07:22 PM
REDinLV
Sep 28, 2015 12:31 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Sep 27, 2015 08:37 AM
