Anyone done a RED LED swap
Old Mar 10, 2005 | 07:54 PM
irish44j's Avatar
retired moderator
I'm getting a bit tired of the blue....want to see what red would look like
My OTHER problem....tried to swap out a few of the LEDs (back windows) with various red lEDs I have (using the correct reisistor) and can't get the damn things to work.
They also won't work on the main window circuit board (driver's side)....either I have all defective LEDs, or I am an idiot....ended up switching the blue ones back in and they work fine.
question: on the driver's window circuit board, WHAT SIZE RESISTORS are they? Are the resistors the little black box things with numbers written on them or not? If I knew what resistors were on that board, perhaps I could figure out why the LEDs I tried will not work...
damn this stuff is frustrating...I've now come close several times to ruining the circuit board, only with some creative soldering keeping them working fine....
Old Mar 10, 2005 | 08:19 PM
irish44j's Avatar
retired moderator
Originally Posted by Maxima260
I belive you need 2.2K ohm 1/2 watt resistor but dont you sue me if you blow up your led. Yes I did that once.
? The resistor depends on the LED forward voltage. We all know that there are already resistors BUILT IN tot he driver's side circuit board for the OEM LEDs....I'm asking if anyone knows what the ohm rating of those are....
edit: guess you deleted your post?
Old Mar 10, 2005 | 08:20 PM
Maxima260's Avatar
I would be careful coz you can fry your electronics. I'm sure LED's for use with 12volts need a 2.2K ohm 1/2 watt resistor.
Don't think I've helped you though...sorry
Old Mar 10, 2005 | 08:23 PM
Maxima260's Avatar
Yeah I was adding my sig wich I made last night. I would look at the lines on the resistors coz you can check by those colors what ohms and resistance of a resistor is.
I still think I can't help you though I'm just shooting blanks here...
Old Mar 10, 2005 | 08:26 PM
irish44j's Avatar
retired moderator
the OEM resistors in the circuit board are not in-line resistors.....I know how LEDs work and all that, I'm asking a more specific question that only someone who's taken apart the switch would know the answer to I guess;
I've already done all the switches with LEDs once...
Old Mar 10, 2005 | 09:09 PM
Max20SE00's Avatar
Hey Irish, I think the blue will look much nicer than the red, but post up pics cause you never know.
Old Mar 10, 2005 | 11:19 PM
Maxima260's Avatar
Wouldn't it be nice if you can adjust the colors... like on my Alpine receiver, I can choose any color I want. but at least maybe make it so you can adjust like the primary colors blue, red, green.., Tuesday I feel like red...ok, Fridays are blue...etc...But that's too hard IMHO
Old Mar 11, 2005 | 06:31 AM
TheBigDu's Avatar
You have one of the newer Alpines? I love this feature about my 9835. I thought it would be tacky and pointless at first, but it's really cool that you can customize the button colors.
Sorry Irish, definitely OT. Now, back to the topic at hand...
I think red might look nice in there.
Old Mar 11, 2005 | 02:39 PM
irish44j's Avatar
retired moderator
Finally got one of the red ones to work....in one of the back doors. I actually bypassed the switch wiring and hardwired it straight into the harness. Let me say...the blue was nice, but I got real tired of it (plus, my 30-year old friends thought it's a little ) Let me tell you though, the red looks awesome on the one switch. Much more classy and subtle. I used 800 intensity LEDs, so it's bright enough to be seen but not so bright it looks cheesy....looks like it could have come that way stock, unlike the blue.
Now....I just have to do all the OTHER switches and radio/climate control
still need to know the resistor size on the driver's side circuit board though!!!
Old Mar 11, 2005 | 03:06 PM
SoonerFan's Avatar
Cletus
well now you can do mine
Old Mar 11, 2005 | 03:09 PM
ZIPPIN's Avatar
Mauja He Mauja
picsssssssssssssss!
Old Mar 11, 2005 | 03:17 PM
Puppetmaster's Avatar
And mine...
J/K... I like my stock look...
Old Mar 11, 2005 | 03:35 PM
irish44j's Avatar
retired moderator
i'll have to find some PINK ones for you.
Old Mar 11, 2005 | 03:38 PM
SoonerFan's Avatar
Cletus
sweet!!! perfect...you big homo
Old Mar 11, 2005 | 03:49 PM
Max_N_Action's Avatar
here ya go....lol
just for u two....ahahahha
Old Mar 11, 2005 | 11:41 PM
Maxima260's Avatar
Yes it's the 9835, isn't it the best stereo ever.... yes it is...
Old Mar 12, 2005 | 06:30 AM
But Josh, pink ones will match your stickers better, esp this one:
Old Mar 12, 2005 | 06:31 AM
SoonerFan's Avatar
Cletus
Old Mar 14, 2005 | 09:01 PM
Triple8Sol's Avatar
I miss the .org!
I really dislike blue, purple, and that kind of stuff. I think red would look good...
Old Mar 14, 2005 | 09:08 PM
Pri63's Avatar
irish, has got me thinking...maybe i'll try the new nissan look, amber...if I do a test run i'll post it...see what the org thinks
Old Mar 15, 2005 | 03:21 PM
irish44j's Avatar
retired moderator
BTW, I have redone the climate control using 11 3mm LEDs (1for each button) as opposed to the 3 5mm LEDs in stock bulb positions, which did not have even light dispersal. Will be putting the new set in when I install stereo (next week?)
Also have one or two little ideas....will post pics when it's all done to my satisfaction!
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
mpbclutch33
Sep 8, 2015 06:21 PM
