Brake bleed order
Old Mar 19, 2005 | 06:29 PM
sambarnett's Avatar
Brake bleed order
What is the bleed order for a 2000?
Thanks,
Sam
Old Mar 19, 2005 | 06:34 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
there is no order... long as you do it to all of them you should be ok..
EDIT: I could be wrong.. check this page out http://forums.maxima.org/showthread.php?t=389452 there is a order in there..
Old Mar 19, 2005 | 07:31 PM
irish44j's Avatar
retired moderator
according to the Nissan FSM, the correct order is:
RR -> LF -> LR -> RF
also make sure to unplug your battery or pull the fuse for the ABS motor when you bleed the system....
Old Mar 20, 2005 | 04:37 AM
RAZORFISH228's Avatar
Why do you need to unplug the battery for the brake bleed?
Old Mar 20, 2005 | 06:23 AM
jimmycapp's Avatar
a rule of thumb is to start at the furthest one from the BMC. RR in most cases. This is the longest brake line.Then work your way down to the shortest.
Old Mar 20, 2005 | 07:23 AM
irish44j's Avatar
retired moderator
Yes, in older cars that most certainly is the rule of thumb that I've always used.....But with ABS and power brake boosters, perhaps something has changed. In any case, I'm more inclined to go with the order that NISSAN says to go in (posted above) than with a "rule of thumb"....
BTW, you unplug the battery because it's the easiest way to de-power the ABS controller/motors (there are other ways to do it too). You want to have them de-powered so that the ABS motors "freewheel" so to say....so that no air is trapped in the ABS system either.
Truthfully, I'm not sure exactly how this works, but I'm willing to take my factory service manual's advice about turning off the ABS and the bleed order...
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
