Catman RSB Installed..I have ?
Old Mar 22, 2005 | 02:17 PM
miksen's Avatar
FU, FU, FU, You're Cool..
I just installed a catman RSB on my max.
It seemed to make a huge improvement in handleing performance.
I bought this used without instructions. I am not sure where the placement of the U bolts should acctually be. Right now I have them placed in a few inches (3-4) from the bends that take the bar to the trailing arms.
They are on the beam obviously but should they be palced differently?
Also it seems my front end is sloppy in comparision now that the rsb is on.
I have a FSTB,,does this sound right to you guys
Can anyone help?
Thanks.
Old Mar 22, 2005 | 02:36 PM
KCMC582's Avatar
i have the Progress one, basically the same thing. my instructions told me to place them 4.5-5" from the bends/corners. im not sure placing the u bolts further out or in will change how the bar works tho. apparently it does on the Addco, but i cant confirm for the Progress?cattman.
Old Mar 22, 2005 | 02:51 PM
ZIPPIN's Avatar
Mauja He Mauja
get the lower tie bar from matt and the front will stop acting like a wh0re on drugs
Old Mar 23, 2005 | 05:25 AM
miksen's Avatar
This car is just a noose around my neck.
It's alway $150 here, $75 there.
I should be a crack addict with the money I sink in to this car.
Rubber alone was nearly $1000.00
I honeslty don't know where you guys are gettign the money to hookup your cars....I would need a parttime job.
Thanks for the info...
Old Mar 23, 2005 | 11:19 AM
Sammzway's Avatar
Sell blood, sperm, sometimes yourself. Whatever brings the money in for some extra horsepower.
Old Mar 23, 2005 | 02:57 PM
ZIPPIN's Avatar
Mauja He Mauja
Old Mar 23, 2005 | 05:36 PM
GusMaxGLE
I here ya bro! I have had my Max for 5 weeks and so far I think I put more money in it than when I had my Toyota for 3 years? I think I am twisted or something.....I may have to give up this car!
Good luck!
Old Mar 23, 2005 | 05:50 PM
Maximax2's Avatar
By U bolts, not sure (can't remember) if you mean the ones on the multi-beam, or the ones on the trailing arms. So will answer both:
I have the multi-beam bolts about 12 inches from the bends, so the right-side one misses the Panhard bar. IIRC, placement of these does not affect handling.
The trailing arm u-bolts are about 2 - 3 inches from the ends, and this DOES affect handling; it increases the affect of the RSB. If you place them farther from the ends, the effect is lessened.
My front-end did not feel sloppy after installation, I have an FSTB and the car is almost perfectly balanced in corners.
Hope this helps.
Old Mar 23, 2005 | 06:13 PM
ZIPPIN's Avatar
Mauja He Mauja
only if you would take some time and check-out the sticky threads
the best write-up i have seen:
http://forums.maxima.org/showthread.php?t=189641
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Alan G
Nov 6, 2000 03:46 PM
