need a New MAF !
Old Mar 22, 2005 | 07:04 PM
99 SE-L
need a New MAF !
hey guys while my car is idling in one place its pinging ,my gas mileage is really poor , very poor high end power, after 40 ,So im guessing Maf whats dave b's number or Site i need one ASAP
Old Mar 25, 2005 | 01:23 PM
jimmycapp's Avatar
Its in the Faq's
Old Mar 25, 2005 | 02:13 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
1-888-254-6060
Old Mar 25, 2005 | 02:15 PM
Igor911's Avatar
Originally Posted by jimmycapp
Its in the Faq's
i put it there
Old Mar 27, 2005 | 07:39 PM
Leviathan's Avatar
Is the Maf covered under the Security Plus Warrenty?
Old Mar 27, 2005 | 08:16 PM
99 SE-L
I contacted dave a couple days back he said a MAF for a 02 Maxima is $390 that is redicously expensive. any other ideas
Old Mar 28, 2005 | 10:56 AM
Anarchist's Avatar
I called my local stealership and they said that the last time it was in they found an "airflow meter" that needed to be replaced for $213 including labor (for a 2000 Maxima SE). Is this not the same thing as the MAF?
Old Mar 28, 2005 | 10:59 AM
Puppetmaster's Avatar
Yes it is... did ya really have to post this in THREE different threads?
Old Mar 28, 2005 | 11:45 AM
Y2KMaxGXE-R's Avatar
Igg-you know the answer, help Alex out...
Old Mar 28, 2005 | 12:07 PM
lex3015's Avatar
its supposed to be like $90 offline about $140 from dealership
Old Mar 28, 2005 | 03:29 PM
jimmycapp's Avatar
i just talked to dave this morning about a maf for my 02. $390
for the 00-01 its about $85 and i was told this would work for my 02 but i need to take a temp sensor or something out of my existing maf and put it in the new one so i dont get a ses light on. Im crossing my fingers
Old Mar 28, 2005 | 03:34 PM
Epacy's Avatar
Unsuccesful STL Coordinator
LOL, my MAF just blew today as well. I just called Dave and he was most helpful. I am going the 00-01 route. He was so helpful. New MAF tomorrow!
Old Mar 28, 2005 | 03:45 PM
99 SE-L
Hey guys can you please explain a little more through on the 00-01 MAF'S on the 02's what happens and what is needed for a good fitment/performance thanks
Old Mar 28, 2005 | 04:55 PM
Epacy's Avatar
I accelerated somewhat hard out of this parking lot then it blew. RPM's dropped and the car eventually cut off not 30 seconds after that. I had to start it 3 times to get it to move. F'ing blows!!
Old Mar 28, 2005 | 05:01 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I'm going with a TTZ MAF in 2 weeks, my MAF has degraded to a point where smoking a 4th gen is a bit of an issue.
Old Mar 28, 2005 | 05:04 PM
Epacy's Avatar
How much is the TTZ MAF? Any differences?
Old Mar 28, 2005 | 05:07 PM
99 SE-L
my MAF has degraded that i always get raped by a 4 th gen 5 speed stock, guys help me out on what i need inorder to use a 00-01 MAF?
Old Mar 28, 2005 | 05:15 PM
TTZ MAF is killer, almost never ever will you see it go bad. Its not a direct plug n play affair thou, and you need the ECU recalibrated to use it. I have Greddy Emanage for tuning and it allows for diff MAFs to be used. I'm sick of repleacing MAFs, the newest design 22680-2Y001 is going into the car tomorrow for now. I got some nasty hesitation at low RPMs and power has seem to gone down. New coils, plugs, MAF and injector cleaning will be done this week. SeaFoam doesn't do ANYTHING to the car.
Old Mar 28, 2005 | 05:21 PM
99 SE-L
Old Mar 28, 2005 | 05:26 PM
jay929rr's Avatar
Hey, if nobody responds about how to make the 00-01 mafs work in your 02 just call dave b and ask him, i know it works i just never done it.
Old Mar 28, 2005 | 07:29 PM
jimmycapp's Avatar
ill post as soon as i know. Something with transfering a sensor in the existing maf over to the new one. plus its $300 less
or just call daveb
Old Mar 28, 2005 | 07:37 PM
00-01 MAF in 02-03 in this thread:
http://forums.maxima.org/showthread....ght=thermistor
Old Mar 28, 2005 | 08:13 PM
99 SE-L
thanks alot Puppet master i will be purchasing a 00 MAF very soon saving me lots and lots of money thanks guys...
Old Mar 28, 2005 | 08:28 PM
No problem... let us know how it all works out....
Old Mar 29, 2005 | 11:22 AM
Epacy's Avatar
I am doing the change-over today for my busted @ss Max!
Old Mar 29, 2005 | 03:37 PM
csvemuru's Avatar
I bought a MAF too. Did not know how to to disconnect the wiring harness on top of the sensor. Please let me know how you did it. Thanks.
Old Mar 29, 2005 | 03:43 PM
Epacy's Avatar
It is like how you disconnect any other wire harness. There is a clip you must push in and then pull up.
Old Mar 29, 2005 | 05:54 PM
jimmycapp's Avatar
Hows it comin??
Old Mar 29, 2005 | 06:25 PM
tisucka's Avatar
quick question...
is there a way i can check if my car has the new or old MAF.... if i take it off will there be a part number on it????????????????
thank you
Old Mar 29, 2005 | 06:49 PM
Epacy's Avatar
Hows it comin??
I was shipped an empty box. Hopefully tomorrow I can get the car online
Old Mar 29, 2005 | 07:14 PM
99 SE-L
You were shipped an Empty box wtff?
Old Mar 29, 2005 | 08:17 PM
csvemuru's Avatar
Thanks Epacy. It helped. Never done it before. Replaced MAF (part number 22680-2Y001) and the car is running great. It was unable to go beyond 3000 RPM and rough idle when warm (used to die after few seconds in park). Seem to have fixed both problems.
Old Mar 30, 2005 | 05:09 AM
Epacy's Avatar
No problem. What year car do you have? Did you have any problems switching over the temp sensor?
Old Mar 30, 2005 | 05:51 AM
csvemuru's Avatar
I have 2000 SE. I will update my profile.
Old Mar 30, 2005 | 06:03 AM
Nathan's Avatar
Originally Posted by tisucka
quick question...
Is there a way i can check if my car has the new or old MAF.... if i take it off will there be a part number on it????????????????
thank you
On the outside of the MAF there will be a part number. You'll need a light or you can unbolt it to make it easier for you. Check what number you have and look in the faq's to see if you're is a new or old part number.
My MAF is also going to blow very soon, but I was able to get a free one through my dealer under the Nissan extended warranty. I even had my jwt popcharged on and the dealer didn't hesitate
Old Mar 30, 2005 | 06:46 AM
... and it will look like this...
And for the numbers:
Originally Posted by Jime
Yes you can get a 2k1 MAF and transfer the sensor or you can buy the AM600.
However the 2k1 MAF is $80 and the AM600 is approx $400. With the discount the prices are a bit cheaper.
Here is what you can buy and the prices.
For the 2k1 there are 2 MAF's available.
22680AD201 $424.73
226802Y001 $90.11 (This is the one that requires the sensor transferred.)
For the 2k2 there are 2 MAF's available
226806N201 $424.73
22680-AM600 $424.73
For the 2k3 there is 1
22680-AM600 $424.73
For more info:
Old Mar 30, 2005 | 07:30 AM
tisucka's Avatar
thanks a lot guys. thats exactly what i was looking for. ill check today.
Old Mar 30, 2005 | 04:59 PM
Epacy's Avatar
Finally!! I got the actual product in the shipment. Getting the temp sensor out was kind of a ***** as it was clamped down under the terminals. Anyway, got it installed and the problem is fixed. Got the ECU cleared and no codes came back. Sometimes the car has trouble starting-the few times I started it today-and it dies out after it clicks over. Not sure if that is aftereffect from the bad MAF or what. But car drives great. Will see if the starting problem goes away.
Old Mar 30, 2005 | 06:08 PM
csvemuru's Avatar
Great. I am wondering if we need the ECU update. The note in the MAF box referred NTSB1-036 TSB. Following is the url for that TSB
http://www.infinitihelp.com/Ownershi.../NTB01-036.htm
I have 2000 A/T california emissions ECU programming part number 23710-2Y173 and it is not listed in the TSB for an update. Would like to know if anyone had this part number and had ECU updated after 22680-2Y001 MAF install. Thanks.
Old Mar 30, 2005 | 06:23 PM
Epacy's Avatar
If you are a 5 gen and not 5.5, I believe you need the update with the new product.
