injen vs berk
Old Mar 24, 2005 | 11:45 AM
chr0nos's Avatar
injen vs berk
Not sure if anyone cares, but I thought I would post this anyway. I had an Injen CAI with Heat Sheild on my Max for about 2 weeks, and it was OK. I notices some low end tq loss, but it moved after 3500RPM. Nice gurgling sound as it sucked in the air. Then I got a Berk WAI with Apexi filter. Better performance all through the power band, but does not gurgle as cool at higher RPMs. It does have a nice sucking sound even at low RPMs though. I think it works better with Berk because the distance from intake manifold to the air filter is a lot shorter. Overall, I think the WAI is better, and more responsive. It may not generate as much tq and hp in the end, but the responsiveness over the Injen CAI and stock air box is definetely better. Peace...
Old Mar 24, 2005 | 11:49 AM
Maxima-Ness's Avatar
I still think its funny how Injen calls it a CAI even though its still in the bay.
Old Mar 24, 2005 | 11:56 AM
NmexMAX's Avatar
dot dot dot ...
Next to the ex manifold.
Check the dyno forum, I did a few tests with various forms of the GAB and a midpipe.
Not ebcause I "felt" an improvment, but actually proved it
Old Mar 24, 2005 | 01:03 PM
thephatOne's Avatar
cant you use the injen as a short ram also? since its two pieces?
Old Mar 24, 2005 | 01:24 PM
SoonerFan's Avatar
Cletus
i keep telling people that Injen isnt as wonderful as everyone claims.
Old Mar 24, 2005 | 01:25 PM
SoonerFan's Avatar
Cletus
if you are going to do that then just get a Berk since its cheaper
Old Mar 24, 2005 | 01:34 PM
Bborges's Avatar
Hey.. I do care!!!!
How do I find info on this setup? Is it sold as an assembly or components?
How much? Any pictures??
Any links to seller is welcome !!
Old Mar 24, 2005 | 01:36 PM
NmexMAX's Avatar
dot dot dot ...
use a coat hangar, probably gives better results.
Old Mar 24, 2005 | 01:41 PM
Bborges's Avatar
got it.
http://www.berktechnology.com
Thanks !!
Old Mar 24, 2005 | 01:42 PM
GBAUER's Avatar
...until if falls off letting dirt clog up your maf, dirty your intake, clog your injectors, and throws a rod!
Old Mar 24, 2005 | 01:47 PM
spiromax's Avatar
Seoul Man
Hey.. I do care!!!!
GOOGLE is your friend. The Berk intake is easy to find. It is sold with all the parts you will need for the installation. The company website is at www.berktechnology.com. They sell the intake with two different filters. You can get the Apexi dry filter or the K&N oiled filter. Personally, I like the K&N, because you can wash it and reuse it. Some people like the Apexi because they don't want to deal with the "hassle" of oiling the filter or risk the (very unlikely) possibility of causing a MAF sensor failure by over-oiling the filter. The Apexi filter is not reusable, though. When it is dirty, you throw it away and get another one, and it is quite expensive compared to the K&N filter.
Old Mar 24, 2005 | 01:59 PM
NmexMAX's Avatar
dot dot dot ...
I look at my engine a lot .. im a lil obessed, i keep close tabs on it. It Hasn't happened yet,
Old Mar 24, 2005 | 02:02 PM
bgates1654's Avatar
"...until if falls off letting dirt clog up your maf, dirty your intake, clog your injectors, and throws a rod!"
I have had a coathangar GAB for 20k miles now with no problems with it falling off. I dont think it can actually fall of unless the coathangar gets bent to hell somehow. Also I use K&N filter grease. The grease makes sure it seals well when installed and actually is sticky enough to hold the filter in properly without the coathangar bracket.
...random hysteria and misconception!
How would it clog your injectors or throw a rod anyway?
Old Mar 24, 2005 | 02:14 PM
NmexMAX's Avatar
dot dot dot ...
It get's dirtier on the top portion of hte filter as opposed as the bottom 1/3 when all closed up. A sign of ore air entering ... I gained ~ 9 whp with it.
Old Mar 24, 2005 | 05:47 PM
PTP's Avatar
PTP
How about any increase in MPG?
Is there any increase with gas mileage (or loss?) with the Berk?
Old Mar 24, 2005 | 06:17 PM
spiromax's Avatar
Seoul Man
Initially, I experienced a loss, because I was always revving it up to hear that great sound. After I got used to the sound and started driving like a normal person again, my gas mileage increased slightly over stock.
Old Mar 24, 2005 | 07:42 PM
Puppetmaster's Avatar
Like Spiro said... the only loss in mpg ya get is from shifting gears at 5k rpms (or stomping on it, if you're auto) just to hear the roar... everyone does it the first couple weeks....
Old Mar 24, 2005 | 07:45 PM
My Berk with K&N...
Got mine for $99 shipped when Berk was having a clearance sale...
Just PM Cobymoby (his real name is Bryan) and find out the current prices and if they're having any sales going on....
Old Mar 24, 2005 | 07:55 PM
No dyno, no care...
Okay, don't get me wrong, I wasn't trying to be a jerk, since you've done more than most of us by trying 3 different set-ups and ya get props for that. Thing is, we've already heard a lot of similar opinions on this in the past, and in general, personal "feel" and the butt dyno haven't proven to be that accurate. The best way to do a comparison would be to dyno the 3 set-ups and let us know what the numbers and plots say (I know, ya already knew this). There's already a comparison that Studman did in the FAQs for the Place Racing CAI, GAB, and a short RAM of some sort (shortened Place Racing), but no one has done one recently with set-ups like the Berk/Frankencar, or Injen/eBay intakes... I think the results will be similar to what Studman found, but we need one to finally end the endless debates...since there're always heated discussions about the gains of those.
Glad ya like the Berk though...
Old Mar 24, 2005 | 08:02 PM
NmexMAX's Avatar
dot dot dot ...
Check the dyno section now, I updated some plots. I saved my money with the berk/injen and used it on a dyno more uselful IMO
Old Mar 24, 2005 | 08:04 PM
Ammi's Avatar
350 Detroit Muscle
Injen sucks all that nice hot air coming from the radiator fan. Definitely not a CAI
Old Mar 24, 2005 | 08:13 PM
NmexMAX's Avatar
dot dot dot ...
It looks cool though :
Old Mar 24, 2005 | 08:14 PM
Great work man... that's good info.... ... ya must have spent a ton of money on those dynos too (unless ya got hooked up) anyways... thanks for the update... I'm thinkin I may check out the GAB set-up sometime...
Btw... do ya have pics of the GAB w/ midpipe set-up? I'm curious to see how ya fit that all in there... I know ya had to cut the mid-pipe a little...
Old Mar 25, 2005 | 12:23 AM
steven88's Avatar
Need A Light?
I was running the GAB for approx 7k miles or so....my car is slammed almost 4 inches from stock on coilovers...and i've hit pretty nasty potholes and dips during the time that I ran my GAB....everytime I opened my engine bay there was absolutely NO SIGN of the filter/coathanger moving at all....The coathanger is bent like hell in a position where it literally grips the filter against the airbox housing....plus i added some duck tape at the tips of the coat hanger to insure added protection of the coathanger not moving during dips....
as far as I know...a correctly made GAB will not fall off...take my experience as a good example....coilovers+low profile tires+stiff motor mounts....still no signs of GAB falling offl
Old Mar 26, 2005 | 01:40 AM
MAX 2NR's Avatar
where do u get coathangar intakes? did a search or google and nothing. do they have a website?
Old Mar 26, 2005 | 04:35 AM
ZIPPIN's Avatar
Mauja He Mauja
should be under the how-2 thread as GAB
Old Mar 26, 2005 | 06:36 AM
StAtiXz6's Avatar
wut u guys think about Frankencar with K&N filtor
Old Mar 26, 2005 | 06:46 AM
super6's Avatar
holy crap someones intake actually fell off? i was thinkin that could happen cause its only connected by that one coupler to the tb. i gotta run and attach that thing better.
Old Mar 26, 2005 | 07:50 AM
SoonerFan's Avatar
Cletus
exact same thing as a berk
Old Mar 26, 2005 | 03:48 PM
spiromax's Avatar
Seoul Man
Are you serious? You don't get the coat hanger intake from anywhere. You make it... with a coat hanger...
Where do you find a coat hanger? Well, I'm not sure if they have a website. Check your closet, maybe?
Old Mar 26, 2005 | 03:51 PM
SoonerFan's Avatar
Cletus
dude you shouldnt have ruined it. you could have cut and bent a hanger and sent it to him for $20
Old Mar 27, 2005 | 12:10 AM
MAX 2NR's Avatar
i didnt know that GAB stood for ghetto air box, so when ppl said coathanger i thought it was just slang for some crappy intake or some tornado crap that was made by GAB. it was a newbie post.
Old Mar 27, 2005 | 10:53 AM
super6's Avatar
seroiusly can someone tell me what the hell is a coathanger intake? now im just so darn curious.
Old Mar 27, 2005 | 10:58 AM
SoonerFan's Avatar
Cletus
http://home.insightbb.com/~dwh/GAB.htm
Old Mar 27, 2005 | 09:41 PM
Originally Posted by soonerfan
Great link...
Old Mar 28, 2005 | 06:03 AM
grange's Avatar
My brother in law and I are making our own intake. Gona have a muffler shop bend us some 3inch exhause pipe. total cost should be 30-40 dollars and the satisfaction of doing it ourselves
Old Mar 28, 2005 | 06:38 AM
NmexMAX's Avatar
dot dot dot ...
Let me know how that goes ...
Old Mar 29, 2005 | 01:05 PM
chr0nos's Avatar
Yah, its rediculous that Berk charges $180 for 10 inch peice of aluminum. But we pay for it, so there is a market.
Old Mar 29, 2005 | 01:10 PM
isn't the $180 for all the components and an Apexi filter?
I think the midpipe alone is more like $60 (not that its cheap)....
Old Mar 29, 2005 | 01:49 PM
chr0nos's Avatar
Yeah, its the whole setup with Apexi filter. But that part cant be more than $50 or 60. So $110 for the aluminium tube? They are making a killing on profit. But I like it, so cant b!tch.
