Spring Protector replacement proceedure?
http://forums.maxima.org/showpost.ph...9&postcount=24
http://maxima.theowensfamily.com/tsb/NTB00-030a.pdf
Has anyone done this? I have never worked on a suspension before. I am tempted to go rent a spring compressor, jack the front of my car up so there is no load on the wheels, then compress the springs so I can replace and glue a new protector to both left & right front springs.
Will the spring deattach itself from the bottom plate as easily as I am thinking? What about from the top, I dont want to reseat this wrong
thanks in advance
thanks in advance
Once you compress the springs you will be able to glue a new protector on without any problems, once you have put on the new protector just start to de-compress the springs and you will be fine. You don't even need to take off the top hat either.
dank4us
34
Jun 10, 2024 03:45 AM
95Maxi
35
Sep 2, 2015 10:37 AM
