WHooo sound coming from wheel area, Help!
Old Mar 29, 2005 | 12:54 PM
Edward Lee's Avatar
Hi, I just noticed this whooo sound coming from the front right wheel area and think that I may need a new bearing or something of the sort. The car has 70k and 18x8.5 wheels w/+40 offset. I say this because I know that oversized wheels can prematurely wear bearings.
The sound is not loud and nobody really notices it. It's only an issue with the driver, ME!
Anyone experience this yet?
Old Mar 29, 2005 | 01:12 PM
maximillien's Avatar
yes I been hearing this ever since I throw on the 350z rims...mines is ANNOYING....im thinkin its the brakes but its only on the right side (pass)
Old Mar 29, 2005 | 01:22 PM
mjg's Avatar
mjg
ask this guy about it...
Old Mar 29, 2005 | 01:34 PM
stupid.........................
Old Mar 29, 2005 | 01:37 PM
UGAd13's Avatar
Whistles like Whoo Whoo!!!
I was thinking the same thing, just didn't post. Good times.
But yeah, could be a wheel bearing.
Old Mar 29, 2005 | 01:38 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I am having the same problem. It is on the passenger side and I can really hear it at low speeds and when I turn at low speeds. Can't tell if it is the brakes-which I don't really think it is or the bearing. Does that sound like symptoms of a bad wheel bearing?
Old Mar 29, 2005 | 01:44 PM
UGAd13's Avatar
Wheel Bearing. GaMax97GLE has the same issue and it is a bad wheel bearing.
Old Mar 29, 2005 | 01:49 PM
can someone lead me to this post so I can read up more on it?
Old Mar 29, 2005 | 02:01 PM
mjg's Avatar
mjg
Eh, relax... It's a joke obviously.
It can be a wheel bearing, or an about-to-go strut, anything wear and tear like that goes with time, I got a noisy wheel bearing in the rear, it doesn't bother me all the time, just when i hook really hard left turns.
Old Mar 29, 2005 | 02:24 PM
Epacy's Avatar
Well My Illuminas are only about 6 months old. Not sure if those are it although I am getting slight nosie from them, front and back passenger side, when I am going slow and over bumps or turning, mostly sounds like the actual spring moving though or compressing of the spring.
I don't believe it is too good to drive around awhile on a bad bearing. Anyone gotten one replaced? How much was it?
Old Mar 29, 2005 | 02:34 PM
brettb's Avatar
O'rly
I have the same issue coming from the front passenger side wheel. Sometimes it is a creaking sound like if something needs to be lubed. I checked my springs and the rubber protector is on the spring so it was not that??? This did this a few months back then stoped, then back again, then stoped, and now back today. If you think your strut is bad, try pushing down on the car a few times and see if you still here this sound. I will be taking mine to the dealer next week and have it checked out.
Old Mar 29, 2005 | 02:40 PM
Epacy's Avatar
Let me know what they find out, but it seems more like creaky springs-minus the bearing/grinding thing.
Old Mar 29, 2005 | 03:38 PM
808MAX-SPEC's Avatar
All of you who are hearing this noise should check your wheel bearing and hub assembly. If the wheel bearing is worn, the hub assembly could be worn as well.
Old Mar 29, 2005 | 04:37 PM
dmitry82's Avatar
do you like your 350z rims??.....ride???....
Old Mar 29, 2005 | 04:45 PM
i love how they look and handle....but they makin so much noise but now I see why I will check soon
Old Mar 29, 2005 | 04:46 PM
ride is about the same....but since the wider wheels I feel alot more of the road..
Old Mar 29, 2005 | 07:13 PM
Epacy's Avatar
Any more news on the cost of replacing wheel bearings? Is it rather easy to do?
Old Mar 29, 2005 | 07:37 PM
Bensmax00's Avatar
do not know how much it costs--but you need some kinda bearing puller or a press--but you gotta take the hub assy off for the press
Old Mar 30, 2005 | 05:10 AM
Epacy's Avatar
So is it something you should take to a shop to get done?
Old Mar 30, 2005 | 07:30 AM
y2KAOSMax's Avatar
I'm having the same problem on my driver's side. It's starting to get annoying. Only happens when I drive slow or turn to the right. How much does a new wheel bearing run?
Old Mar 30, 2005 | 10:27 AM
FriscoMaxima's Avatar
it might be your wheels. i used to have 17x7 on my car at one point and one of them made a horrible humming sound. i changed to 18x8 (a new set) and the car is quiet.
Old Mar 30, 2005 | 10:34 AM
96max5sp's Avatar
I had 2 bad wheel bearings, cost about 250-275 each time
Old Mar 30, 2005 | 11:23 AM
Epacy's Avatar
Did you go to a local shop or the dealer?
Old Mar 30, 2005 | 12:04 PM
96max5sp's Avatar
One time was at Pep Boys and the other time was at Firestone
Old Mar 30, 2005 | 03:45 PM
I think that's about right. Forgot how much I paid in total because I had to replace the wheel bearing and hub asembly. My friend said the sound was not coming from the brakes so I was a bit concerned. So i just took my car to the dealer.
Old Mar 30, 2005 | 05:52 PM
mines sounds like the brakes tho, hear it grindin against my rotors because i hear as they rotate hitting the same time when it gets to that point....i dunno if i explained myself nicely enuff!
Old Mar 30, 2005 | 05:59 PM
Epacy's Avatar
i hear rotating grinding as well. Just am not sure what is the actual problem.
Old Mar 31, 2005 | 06:06 AM
y2KAOSMax's Avatar
Mine sounds like the brakes rubbing too but it's not. I just put on new rotors and pads a few weeks ago. I had the problem before I put them on and I still have it now. I'm pretty sure it's the wheel bearings. I found a place online that sells them for $55. Now I just have to find someone to put them on.
Old Mar 31, 2005 | 06:13 AM
Epacy's Avatar
Link me for the bearings. Thanks.
I need to put on new rotors and pads too, but I didn't know if that would fix it.
Do you hear the noise at low speeds or when you are turning? It isn't too good to drive on bad bearings for too long is it?
Old Apr 1, 2005 | 03:47 PM
found the problem! its the pads eating my rotors....****! oh wellz brembo cross drilled here I comE!
Old Apr 1, 2005 | 05:04 PM
jkayca's Avatar
Hearing something on my max too. It's coming from the front passenger side. I don't think it's the brakes since I hear it without applying them. I only have 78,000 kms (52,000 miles) too
Old Apr 1, 2005 | 06:36 PM
check it tho, mines did the same thing but after awhile it gets worst now its eaten into my rotor!
Old Apr 1, 2005 | 08:48 PM
Epacy's Avatar
I just wish I could tell if it is my brakes or wheel bearing. There has to be a way. I hear the noise without braking but that doesn't mean it isn't the brakes. I am leaning towards bearings though.
Old Apr 2, 2005 | 12:20 AM
I had that same problem. I could be accelarating or coasting at a slow speed and hear noise. The service manager said when they lifted the car they could actually move the wheel just a little, even though it was bolt on. He said i was lucky that i brought the car in when i did. Not sure if this is worth doing but you could try jacking up the car and try jerking on the wheel. Not sure how much movement would constitutes to say that it's the wheel bearing, but it might be worth a try. If not, take it to a shop and have it checked out. Hope this helps.
Old Apr 2, 2005 | 03:50 AM
jkayca's Avatar
It's almost time to take off my snow tires. I guess I'll look at it then.
Old Apr 3, 2005 | 10:48 PM
y2KAOSMax's Avatar
You can get them here.. I hear the sound at slow speeds and whenever I turn to the right. I need to find someone to put the bearings on for the low since they don't cost that much..
Old Apr 11, 2005 | 08:21 AM
brettb's Avatar
O'rly
UPDATE - my problem was the wheel bearing and the hub were worn.
Old Apr 11, 2005 | 09:48 AM
ScottMax04's Avatar
Similar problem here
Evertime i hit a small bump in the road the damn wheels make a squeeking sound. its small enough for just me, the driver, to hear but large anough to **** me off. i've brought my 2k3 to nissan about 5 times just on this but they cant figure it out. they thought it was something in my trunk so i completely emptied my car out. the squeek is still heard. i cant hear it at fast speeds but at slow speeds its annoying. Right now the only solution is the volume control to make the music loud enough to not hear the squeek. Anyone else have a similar problem or know what the cause could be or how to fix it???
Old Apr 11, 2005 | 09:55 AM
Epacy's Avatar
Mine was my bearing too. I got it replaced last week. A good way to tell is if you jack the wheel off the ground and then push in on the wheel from the bottom of the wheel and see if there is any play in the wheel. You shouldn't be able to push it in or out. If so, that means your bearing is worn.
Old Apr 12, 2005 | 04:33 PM
Tical6's Avatar
mine does the same thing...dealer said they checked the suspension and it was fine ....i thought i had read a posting on somewhere on this site about the squeaking coming from the little rubber thingies on the car that the hood rests on (?????i dunno what they are called, sorry!) i haven't bothered to take it back to the dealer--they are just going to tell me they cannot duplicate the problem. nissan dealerships bite
