View Poll Results: Which Rotor is best for an 03 max
OEM with OEM pads
12.33%
Brembo Blanks with OEM pads
45.21%
RTP Slotted Rotors from GD with axxis pads
25
34.25%
RTP Blanks Rotors from GD with axxis pads
8.22%
Voters: 73. You may not vote on this poll
OEM Rotors Vs. Aftermarket which ones do you pick?
Old Mar 30, 2005 | 07:00 PM
R.I.P. Grandma's Avatar
When i drive at high speeds on the highway and apply the brakes the whole car starts to shimmy. I believe that my rotors are warped and was looking to get some new ones. ive spoken to a few mechanics and they all told me that Oem is the best rotors and any that i shouldnt consider anything aftermarket. Also i was told that blanks are the best type of rotors and that either slotted or cross drilled would not increase my braking performance and will actually warp faster.
So my question is simple which rotors would you choose?
Old Mar 30, 2005 | 07:34 PM
from the research i have done so far, Brembo Blanks are more recommended then anything else. They supposibly dont warp as fast and provide better braking then OEM. Everyones comments are welcomed.
Old Mar 30, 2005 | 07:48 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Frozen rotors are the best...
Old Mar 30, 2005 | 08:02 PM
Frozen Rotors are probably twice as much as Brembo Blanks right?
Old Mar 31, 2005 | 12:37 AM
HTownMaxSE's Avatar
do they make brembo for 5.5 gen and where can i find it? My rotors are warped bad, Need new ones asap. I was thinking about getting the RTP ones from the group deal
Old Mar 31, 2005 | 05:18 AM
nicks79's Avatar
Can you list your sources of reasearch? I'd like to read up some more.
Brembo blanks are around $40 each. Frozen ones are $125 each. I'll use OEM pads, just because I already have them - inherited with the car.
For those with physics and chemistry knowledge : what do you think will happen if you dit Brembo blanks in liquid Ni. Is that close to the same process as frozen rotors are put thru?
Old Mar 31, 2005 | 12:53 PM
After speaking with Automax again i feel confident in his comments and his belief that RTP zinc plated slotted rotors will perform better then OEM rotors and will not warp. I guess im going to try out the RTP/Axxis combo in a couple of weeks, unless someone else has something else in mind.
Old Mar 31, 2005 | 01:01 PM
GujuMax00's Avatar
I ordered the Brembo Blanks for my 00 Max, and im using Raybestos Quietstop Pads... The pads worked good on my OEM rotors, we'll see how they perform with my Brembo Blanks. I awaiting my new rotors. If you want to order them contact Automax_95 a.k.a Jason. He's awsome person to get them from. Prompt responses, shipping, nothin but positive feedback, etc... Recomended A+++ (what is this ebay?)
-Andy
Shift_Inspiration
Old Mar 31, 2005 | 01:27 PM
spiromax's Avatar
Seoul Man
Going with OEM rotors is a good idea sometimes. In our case, the OEM rotors are KNOWN to warp easily, so going with aftermarket rotors isn't bad as long as you pick your rotors wisely. Brembo and RTP are both good companies, but I don't believe you can get a full set of front and rear Brembos yet, can you? I know you can get RTPs in the right size for a 2002/2003 Maxima. Somebody correct me if I'm wrong.
As for the drilled/slotted question, I recommend slotted rotors. Drilling is theoretically good for braking performance, since it allows materials trapped between your rotors and pads to escape, but OEM sized brake rotors often operate near their thermal design limits, especially when you're using high performance aggressive pads. If the rotors aren't drilled properly, their strength under conditions of extreme heat and stress can be compromised, allowing them to crack. Slotted rotors allow any trapped material between the pad and rotor to escape just like cross drilled rotors, but they don't cool down quite as fast. I think that it's a fair trade, though, considering that they tend to crack less.
Here's a direct quote from Mike Kojima, who writes for Nissan Performance Magazine:
"Rotors are drilled because the drilling lets vaporized pad material escape from under the pads, minimizing the hydroplaning effect under hard braking thus giving the pads better grip under these extreme conditions. Drilling also lets water escape in much the same manor in rainy weather. Test done by KVR show that drilled rotors can cool down up to 20 percent quicker than solid rotors. Drilling also helps deglaze the rotors or keeps them from glazing up due to a cheese grater effect.
I myself think that drilled stock rotors or sport rotors may be somewhat questionable because since small stock brakes are run close to their thermal limit with high performance pads, the drilling can contribute to cracking. If you are buying drilled rotors check to see if the holes have be chamfered. Chamfering helps reduce the likelihood of cracking. Drilled solid rotors like the rear rotors on SE-R’s make a weird whirring noise when the brakes are applied. Some people have said that drilled rotors cause faster pad wear but I myself have not experienced it. Drilled real racing brakes with sufficient thermal capacity are functional and useful. Better than drilling but perhaps lacking some of the racy pizzazz are slotted rotors. Slotting does the same thing as drilling but without the cracking problem. I don’t think slotted rotors cool any faster but they are a lot less likely to crack. If you are running stock sized rotors , I’d go for slotted for this reason.
Overall, I feel that drilled sport rotors are mostly a cosmetic trick and have never tested drilled, slotted and solid back to back. They really look cool though and fall in to the disco/rice boy category as all of my personal cars have them!"
Old Mar 31, 2005 | 01:40 PM
very informative post. Thank You.
Old Mar 31, 2005 | 01:52 PM
Lumbee1's Avatar
Frozen rotors
lasts 2 to 3 times as long as standard rotors. I didn't want to buy Brembo and have to get them cut at 15K miles. If I wanted that kind of performance I would get OEM again.
http://www.frozenrotors.com
Old Jun 9, 2006 | 04:43 PM
sciff5's Avatar
OEM rotors and a good set of pads that dont transfer material, which is what happens most of the time making people think their rotors are warped when they actually arent
Plus I just bought 6th gen front rotors for 25$ a piece and they were pretty much brand new. You cant beat that deal.
Old Jun 9, 2006 | 04:47 PM
knight_yyz's Avatar
Toolie
Sure, if you want to completely ruin them . Cryogenic heat treating is a slow process, you can't just dunk a piece of metal into something that cold and expect it to survive. Also after they have been cryo'd they would have to be tempered (warmed up slowly) depending on the material (usually 300 to 500 F)
Do not try this at home!!
Old Jun 9, 2006 | 07:30 PM
MyBlue02's Avatar
Originally Posted by Lumbee1
Frozen rotors
i did brembo blanks on my old car (99 gtp) and put 30,000+ miles with ceramic pads with absolutly no turning needed...no warping either...and that car was an auto.
Old Jun 10, 2006 | 09:49 AM
meccanoble's Avatar
Sports Button FTW
rotors are one of the biggest issues with our cars because we have the same size as 4th gens with more weight and more power to stop. Remember, if u cheap out and not make the right decision, u gonna spend twice if not 3 times as much in the long run, not to mention the time wasted on labor.
I have seen TOO many stories of new rotors (whether stock and ESPECIALLY aftermarket) get warped within less than 1k miles or a little after....worst feeling is making an investment and not seeing its value. I have high quality drilled AND slotted rotors from a very strong company called Racing Brake that supplies many other high level companies. I also have hawk pads which tend to squeek sometimes but recently having given me any issues. I also see dust form but it takes a while. Either case, my rotors have no warped on me at all and i have put between 10 and 15k miles on them. Very happy with them and if u need just blanks, u can get them cheaper. Many fear drilled rotors crack under a lot of pressure but its mainly because of the quality of the rotors.
My strongest recommendation is RB rotors but either way, through my mistakes in the past, i know what u can get into if u dont do this right. It's not like spark plugs or an oil change anyway, u dont want to keep doing this job. Its messy, time consuming and just a PITA. Good luck wit your choice and if u have any questions about RB rotors, holla @ me or swoods@racingbrake.com <~!~ if need be, let him know i recommended you.
Old Jun 10, 2006 | 10:04 AM
Mizike's Avatar
RPT rotors from Jason (AutoMax) and pick up a set of Hawk HPS pads from a website of your choosing FTW. Make sure to bed them in properly as soon as you install them. You will not be disappointed. By the way, Jason is a great seller and gives great customer service. People have said that Axxis pads dust like a **** and are loud (squeaky) as hell. Good luck on your decision.
Old Jun 10, 2006 | 04:18 PM
joeyd's Avatar
i have the zinc plated rtp rotors from jason...they havent rusted at all..and still look great....my buddy has some brembos and they rusted pretty quickly
Old Jun 10, 2006 | 08:05 PM
Stereodude's Avatar
I second the recommendation for the zinc plated rtp rotors from Jason. The Axxis Ultimate pads are squeeky, though I haven't really noticed excessive amounts of dust. I think I'm going with Hawk HPS pads next time though.
Old Jun 10, 2006 | 09:17 PM
mdemonte's Avatar
Power slots rotors with Hawk Pads
Old Jun 19, 2006 | 06:56 AM
LoSt180's Avatar
I've put some Brembro blanks on last summer, because the last rotors were warped. It's starting to do the same problem RIPGRANDMA posted. Glad I read this thread, I was starting to think something was wrong with MY car, now I see it's a maxima-wide issue....
Old Jun 19, 2006 | 11:49 AM
SinCityMaxPower's Avatar
Nope, Nissan definitly went with an undersized rotor with the MAxima. I guess it was one of their ways to keep the cost down.
Old Jun 19, 2006 | 05:03 PM
rmd0311's Avatar
Hmmm.. Just bought plain Brembo's with Axxis Pads for mine today... Should be here end of week...
Let's see how it rolls..
Old Jun 20, 2006 | 07:55 AM
Spartuss's Avatar
get some bendix rotors. they come with a 2 year replacement if they ever warp.
Old Jun 20, 2006 | 06:50 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Power slots rotors with Hawk Pads (HPS).. best combination ever....
Old Jun 22, 2006 | 05:42 PM
SCT.MAX's Avatar
Anything but OEM.
Old Jun 22, 2006 | 05:57 PM
sciff5's Avatar
Originally Posted by SCT.MAX
Anything but OEM.
I have found the 6th gen OEM rotors are quite good. Just get some good pads
Old Jun 26, 2006 | 10:38 AM
fletch126's Avatar
Have Brembo blanks and Axxis Ultimates all around for almost two months. No squeaking or dusting. I might have a rear caliper sticking though. Can't blame that on the rotors and pads.
Old Jun 27, 2006 | 08:57 AM
bestofbothworld's Avatar
ive been away from this forum for quit some time and dont have very many post, but the ones i chose were the I-rotors drilled and slotted w/zinc platting and EBC yellows for the front and greens for the rear with Crown Performance steel braided lines.
Old Feb 22, 2007 | 10:31 AM
98sebring's Avatar
On my 2003 GLE daily driver, I have 175,000KM. OEM are way over priced, I went with Chinese rotors availabel from NAPA for $25-30 each and OEM brake pads.
Old Feb 22, 2007 | 10:51 AM
housecor's Avatar
I went w/ Brembo blanks and Hawk HPS pads on all 4 corners to replace my warped OEM setup. The new setup is quiet, smooth, and produces very little dust. Only around 5k on the new setup, but so far I'm pleased. My only complaint is the Hawk pads lack bite when cold but warm up within a minute or so.
Old Feb 22, 2007 | 10:57 AM
MidN1te's Avatar
WEll i purchased the R1 racing rotors and brakes.....they are drilled and slotted and boy do they stop on a dime and hasnt warped yet, but i only have around 5-6k on them now though...but for 186 bucks for all 4 rotors AND brakes? good buy.
Old Feb 24, 2007 | 09:33 PM
clayman88's Avatar
Guys, thinking about getting Brembo blanks & Hawk HPS's. This may be a dumb question, but are the Brembo blanks any bigger than the OEM rotors?
Also, anybody have an opinion on the Zinc plated rotors? Does it look any different & do they really keep your rotors from rusting up?
Old Feb 25, 2007 | 12:12 PM
housecor's Avatar
Brembo blanks are the same size.
Old Feb 25, 2007 | 06:21 PM
jeremysyty's Avatar
Brembo's blanks are awesome! The local deer population like them also!
Old Feb 25, 2007 | 07:19 PM
kingrukus's Avatar
no more maxima...
brembo blanks
Old Feb 25, 2007 | 10:58 PM
duderiffic's Avatar
Where is the best place to buy Brembo blanks? My brakes are pretty noisy and a little sketchy on abrupt stops... thinking probably best to replace everything.
My Max has 74k on it of reasonably calm driving... should expect to replace my rotors at this point in time on the Maxi?
Oh, another thing... can you find 2002-2003 Brembos? It seemed that some websites said they had them and some didn't have rears...
Old Feb 25, 2007 | 11:52 PM
PerfectVQ I30's Avatar
Brembo Sports Slotted
made with carbon and iron. Blanks are iron only and warp easy.
Also i use akebono pro ACT ceramics, WOW my ABS chirps loud 3 times and damn it brakes hard. still no warp =)
Old Feb 26, 2007 | 05:35 AM
abcito's Avatar
take a look at this
I just ordered a set for 90.80 shipped
http://forums.maxima.org/showthread.php?t=512135
Old Feb 26, 2007 | 07:27 AM
rmd0311's Avatar
Check OUT http://www.importrp.com
I bought my brembo blanks there. Real good price.
55 for the fronts and 40 for the rears.
Can't beat that...
Old Feb 26, 2007 | 08:43 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
brembo blanks ftw. for normal daily driving, you just need rotors with the most surface area for contact.
