Will this fit my 03?
Old Apr 5, 2005 | 10:14 PM
Snolife's Avatar
What we have here is a failure to communicate
Just curious, not sure if this would fit or not. Thanks for any help.
http://www.shopmomo.com/automatic.html
Old Apr 5, 2005 | 10:18 PM
bigsherv's Avatar
No, our stock one does not have a button. All of those do. Buy a regular manual **** by momo.It will fit fine.
Buy one like this
Old Apr 5, 2005 | 10:27 PM
tothemax319's Avatar
Bigsherv is right.. Just wrap the stock **** in an old t-shirt and loosen that sucker up with some channel locks. And when thats done, you're open to install pretty much any manual shift ****.
Old Apr 5, 2005 | 10:39 PM
Snolife's Avatar
ok, a little confused here, I have an auto. do you know where I can get one? According to that web site, the manuels will fit the auto's?
Old Apr 5, 2005 | 10:46 PM
Snolife's Avatar
ok, after a little reading, it is my understanding that the manuels will fit my auto because I have not button that needs to be pushed. so therefor this one should work,right? Thanks again.
http://store1.yimg.com/I/shopmomo_1838_735276
Old Apr 5, 2005 | 10:47 PM
whazzzzuup's Avatar
Our automatic transmission shift ***** (2002-2003) do not have the release button, so you can screw a normal manual transmission shift **** on there. Just make sure you don't buy a shift **** with gear numbers on it (which are rare anyways) and everything should be fine.
Old Apr 5, 2005 | 10:51 PM
Snolife's Avatar
Makes sense, thanks for all of your help every one.
Old Apr 5, 2005 | 10:59 PM
On an unrelated note... I was just drooling over this same **** for my 6-speed before you posted the link. Unfortunately, Momo doesn't make this model to fit with the 02-03 Max's reverse lock-out collar.
Old Apr 6, 2005 | 06:29 AM
Snolife's Avatar
So, this will not work then? Thanks. Im confused as heck.
Old Apr 6, 2005 | 06:33 AM
AcerX's Avatar
www.customenterprise.com has a nice carbon fiber auto shifter
Old Apr 6, 2005 | 06:37 AM
Stardust's Avatar
F---ing Kangaroos
It won't work with the 6-speed, it would work fine for you.
Old Apr 6, 2005 | 07:06 AM
Snolife's Avatar
Cool, thanks again for all your help.
Old Apr 6, 2005 | 10:11 AM
bigsherv's Avatar
really like that shifter? Doesn't the stiching gross you out? Why not get one of these
do you
Old Apr 6, 2005 | 10:37 AM
Puppetmaster's Avatar
Yeah, the selection is limited... I think this is the only one that looks decent...
http://forums.maxima.org/showpost.ph...9&postcount=95
There are more here with reverse rings here:
http://www.cardomain.com/shop/list.p...tart=1&show=93
Old Apr 6, 2005 | 11:07 AM
Snolife's Avatar
do you
Now that you pointed that out, Im having second thoughts, probably will go with the second one.
Old Apr 6, 2005 | 03:44 PM
ag2k's Avatar
That 2nd one looks tight.
Old Apr 6, 2005 | 08:02 PM
XGaSpAcHo
i like these more...
Old Apr 6, 2005 | 08:08 PM
I'll soon be ordering the 3rd one (half leather, half aluminum). It's probably the best looking Momo that's available in a shorter stack for 6-speed Max's like mine with the reverse lock-out collar.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
