Engine Drive Belt Replacement
Hey Folks, need some help. I was trying to replace the engine belts on my 2002 3.5L Maxima. Not sure what the purpose of the Idler Pulley is and how to go about releasing the tension on this unit to replace the alternator/water pump/power steering belt, the thicker belt. I have no idea how to get at the A/C belt, the thinner. Any ideas or refrences would be greatly appreciated.
Thanks,
wolfman
Thanks,
wolfman
if it is the same procedure as the 00-01, then there is a link on HOW TOP, but I couldn't find it. I know it has to do with "MOTOVATE", I will do a search for you....
Search done
http://www.motorvate.ca/mvp.php/500
http://www.motorvate.ca/mvp.php/501
The instructions are for HOW to Change your Alt, but it will be the same.. to replace the belt
Good luck
Search done
Good luck
Thanks a lot Lontar1 and theMax. That's exactly what I needed for the fat alternator belt replacement. The whole trick was loosen the idler pulley bolt as well. If anyone has similar info for the smaller power steering belt that would be much appreciated.
Thanks,
wolfman
Thanks,
wolfman
Thanks theMax. I'll look for that bolt. If I can't find it I'll email you.
wolfman
wolfman
Originally Posted by theMax
power steering is a little different. There is a bolt behind the pump that moves the whole pump to get slack. email me and i can send pics
Hondarydr
Dec 30, 2024 06:15 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
