FSTB and RSB
I've been reading the threads and it really got me contemptating get the FSTB and RSB. The SE's handling is pretty tight but at high speeds, it leans some (vs. my 240sx). I would like to get it as close to the feel as possible.
The FSTB only really affects steering response, right?
As for the RSB, Doesn't the stock SE have one already? If so, how then does the Stillen go on. Just replace the old one?
Thanks.
Thanks.
The FSTB will improve steering response and feel. It will stiffen up the front also. There is no stock RSB on the max...so it will be a straight bolt on. Get the two....you will feel a big difference guaranteed
Originally posted by punkdork
If you want to reduce body roll, RSB is the way to go. It complements the existing sway bar. Check the how-tos for install pics.
j/kHow'd I know if I saw the words "sway bar" or "RSB" in the thread title you'd make your mark in here.
Hey, since I ordered one, why don't you get one, too.
Originally posted by RcticMax
Of course, this advice comes from a man who's installed a Stillin RSB before... oh, wait a sec... nope, that wasn't you after all... hehehe
j/k
Well you can't blame me if I've got a lax job.
You buying?
[/B]
You buying?
[/B]
You got a "lax job"? Boy, that musta hurt!
high speed handling
I'll admit I haven't done a complete search on this topic, but since we're on the subject.
Does the FTSB and RSB mod improve the Max's overall high speed handling? I feel that the Max's high speed handling (around 70m.p.h+) could use some improvement, but I don't know if it's a tire issue, or what (stock Bridge potenza's).
If the FTSB and RSB aren't the answer, is there one? Thanks.
-J
-J
Yeah, high speed handling will be a lot crisper with these mods. Less body roll and an increase in stiffness helps at high speeds.
As for whether or not the max has a stock sway bar, I don't think so.....I could be wrong though....But either way, the RSB is a bolt on that does not replace any existing parts....
Re: high speed handling
-J
-J
Re: Re: high speed handling
FSTB should tighten up the steering response and RSB reduces body roll.
Either way...you and Kev are just ****** on this posting thing.
k:Quick delete that post!
p:No, you've responded, now you'll have to delete yours
k:No, work faster
p:Quick, respond to 20 posts in 10 minutes.
YOU ARE KINGS!!!!!!! How can I be like you!
Re: Re: Re: high speed handling
Originally posted by Michael98033
Am I just a fool or did you just change to "Needs non-Maxima Friends".........???
k:No, work faster
k:No, work faster
BTW, I got the non-maxima friends a week or two ago.
Re: Re: Re: Re: high speed handling
The main thing to remember is to post off topic a lot and get into personal conversations in threads.
So, let me get this straight...you've need non-maxima friends for the past week or two and I didn't notice. Am I blind or what?
Was that good?
Re: Re: Re: Re: Re: high speed handling
Let me try...
Was that good?
Let me try...
Was that good?
....hey, you catch on pretty fast
nice job.....a smooglie for you:
Either way...you and Kev are just ****** on this posting thing. :cheese
k:No, work faster
:jump
k:No, work faster
:jump
Congrats on the promotion. Too bad it isn't this easy at work.
Hey, quit pickin' on me or I'm taking my ball and goin' home
Originally posted by PhatGuy
If you have the FSTB and RSB is the RSTB all that necessary? Is it worth the money/perfomance to have a RSTB installed with the FSTB and RSB? How much difference in handling is going to be felt with the RSTB?
RSTB will not give you much of an improvement. Save your money for something else.
Originally posted by walsh03
Yesterday I installed my new FTSB, and man oh man, what a difference. Now I want to look at a RSB. Can anyone give me their input on what to buy and where to get it?
I'd agree with that, bushings seem sort of bush-league in comparison to the brackets...
Tip: You have to compress the stillen rsb to fit it between the brackets, I tightened one side completely and then used the brackets on the other side as levers to compress the rsb...get jack stands...take your tires off...
Originally posted by UMD_MaxSE
I say go with the stillen RSB....The price difference is more worth it.....
Can some answer me this. On the brochure, the SE model has "front and rear stabilizer bar". Does this mean front and rear sway bars?
I thought so but someone told me the Max doesn't have RSB, hence get one. I looked underneath the car from the back and couldn't see one.
Originally posted by Y2KevSE
What to buy? I'm sure punkdork can give you an answer on that because he's had both kinds or RSB's. Where to get one? Check the Parts List thread.
I've got a 2001 SE that has the Stillen front strut brace and the rear sway bar. Both offer great improvements. The steering is more responsive and the car seems to corner absolutely flat. Well worth the price. Go for it.....
stock max DOES have a RSB!
Look at the rear axl. The stock sway bar is under (in) it. You can see from under the car. The stillen RSB mounts right under it. I think it doesnt look like a typical RSB because we don't have independent rear suspension (why a RSTB doent really do much).
I have the stillen FSTB and RSB and love them both. Good handeling in turns. on/off ramps beware.
Re: stock max DOES have a RSB!
Originally posted by theMax
...on/off ramps beware.
Fire Extinguisher at the ready
What's that mean, are you talking about the tire grip at the limits, or is it a warning to other drivers that you can go faster on the ramps and thusly merge more quickly?
That's what I'll be saying when I get my RSB installed (due to arrive this week)!
you got it RcticMax!
The max holds much better especally on on/off ramps. I can hold much higher speeds and hit most merges at highway speeds. Also I don't need to apply brakes before exiting. All on stock tires (for now)
Thanks.
Thanks.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
