How to take rear door apart???
4) Feel around on underside of door trim and you will feel a small gap in which you can place your fingers. This part is kinda tricky. Put your fingers in there and pull to disengage the lower clips. Just don't yank too hard or some clips might break. Then work your way around the edges of the trim to disengage all clips. There are a total of 5 or 6 I believe. You will eventually be able to just lift the panel up and out.
pull the door trim toward yourself, be careful the clips could break and that would be a b!tch. There should be 3-4 clips on the door. also did u take the trim off from the door handles? that could be blocking it also.
doctorpullit
Sep 10, 2015 06:33 PM
