speed bleeders, do they really work?
Old May 8, 2005 | 10:44 AM
super6's Avatar
when i installed my speed bleeders few months ago (the ones with the "one way valve") i blead the brakes and they still feel mushy. the speed bleeders ( www.speedbleeder.com ) claim u just open the bleeder and pump the brakes as much as u want and close, the spring valve doesnt let air back in. but a few people told me thats crap, and u still have to do it the old way. is that true??? and if they do work why dont my brakes feel solid??
thanx!
Old May 9, 2005 | 09:43 AM
Eric Holmes's Avatar
They are a waste of money...
I bought a full set of speed bleeders for my Z32. I spent a huge amount of time and brake fluid giving them a chance to do their job...they did not. In particular, the clutch simply would not bleed until I used the "old fashioned" technique.
Old May 9, 2005 | 10:31 AM
Matt_01SE_20th's Avatar
speed bleeders use a normal check valve to allow the fluid to flow in one direction. this technology works on a daily basis in millions of applications. as an engineer in diesel engines i know that these valves work, as we use them in all of our fuel systems and most of our oil supply lines.
as a bleeder these should work great. i dont know what you are saying about doing it the "old" way. the old way should be that you have to lossen the bleeder, depress the pedal and then retighten the bleeder, then release the pedal. the speed bleeder simply allows you to pump the pedal repeatedly without retightening. you still need to do everything else the same.
i have never had a problem with doing it the old way but i am thinking about getting these for both my clutch and brakes when i replace the lines.
Old May 9, 2005 | 03:54 PM
maxfive-O's Avatar
Vacuum pump works the best. Just don't forget to monitor the fluid level.
Old May 9, 2005 | 04:06 PM
foodmanry's Avatar
Da Roller Coaster!
I've had speed bleeders on my max for years. Haven't had any issues with mushy brake pedal or air in the system. It takes me a total of 10 minutes to bleed all four brakes with the speed bleeders...freakin easy.
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
