Grounding Kits??
Old May 26, 2005 | 11:23 AM
Ryals's Avatar
SHIFT_this
Grounding Kits??
Not asking what they do. I've read 100's of threads on that. I was just curious as to which brand or companies are good to buy from. Is more expensive better? Is it not possible to use the Courtesy Nissan ground kit on a 2000 Max? I crossed a company call Activetuning with a good price on Kits. Has anyone istalled this kit? How is it?
Old May 26, 2005 | 11:31 AM
nissan5788's Avatar
Why not just make your own? http://www.cardomain.com/memberpage/442543/16 courtesy: irish44j
Old May 26, 2005 | 12:03 PM
Ryals's Avatar
SHIFT_this
Because I'm not that much of a DIYer when it comes to things under the hood. I also read that it cost around $30-$40 for supplies and I've crosses this company that sells for that w/ free shipping.
Old May 26, 2005 | 12:27 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Blehmco. He's a fellow orger and quality is top notch. Everything is exactly cut to length.
Blehmco
Old May 26, 2005 | 12:29 PM
scopium
yea blemco.. i have his ground kits
they r nice
Old May 26, 2005 | 12:30 PM
Puppetmaster's Avatar
Blehmco
I'd get it from Matt too....
FYI, there's also someone from Active Tuning selling it for $40:
http://forums.maxima.org/showthread.php?t=403193
Old May 26, 2005 | 12:42 PM
Ryals's Avatar
SHIFT_this
Yeah thats where I saw the kit!!
Old May 26, 2005 | 12:47 PM
Ryals's Avatar
SHIFT_this
Blehmco
How do you contact or purchace from here?
Old May 26, 2005 | 12:49 PM
Using the information from here:
http://www.mattblehm.com/contact.html
Old May 26, 2005 | 12:51 PM
Or send him a PM:
http://forums.maxima.org/member.php?userid=46
Old May 26, 2005 | 01:30 PM
irish44j's Avatar
retired moderator
The home-made grounding kit costs about $20 in materials, and that's if you buy more than you need. It takes about an hour or two to do, and is pretty much child's play (a "beginner" DIY mod).....
If you're buying a pre-made one, I'd suggest going with the Blehmco one, since it is cut to fit the Maxima correctly.
Old May 26, 2005 | 03:55 PM
London SE's Avatar
I picked up an HKS "Circle Earth" ground kit at cost from a
friend and its a nice looking setup, Gold distrubution block Gold Connectors
Etc, I know some will say its overpriced bling, but it works well
and looks nice,
Plus I am in love with all things HKS.
To each their own, but it was my choice over a DIY setup.
Old May 26, 2005 | 06:10 PM
claudiusmaximas's Avatar
im lookin into that active tuning kit...sounds pretty damn good being that it's only forty bucks...
Old May 26, 2005 | 06:17 PM
amomaxima's Avatar
so if i am a DIYer and i have 5 gauge wire would that be acceptable for the grounding of a 5th gen. I figure why spend more money when i have already got what i thinkis efficent. What are the home depot guys using or does it not matter to much. Also what kind of ring terminals are they using, basic zinc or gold.
Old May 27, 2005 | 12:53 AM
Ryals's Avatar
SHIFT_this
Yeah I just purchased the activetuning ground kit, I was shocked that it was still $40 free shipping even to Alaska. Can't beat that!! Guess I'll see how good it really is when I recieve it.
Old May 27, 2005 | 01:22 AM
AllMaxxedOut's Avatar
I have MattBlehm ground kit as well. But with some connectors & speaker gauge wire, you can makeyour own ground wire (just like someone else mentioned here). Then again, it's not that expensive for the kit either so it's your choice really. You can also get them on southwestautoworks.com, along with the other kits everyone mentioned here.
Old May 27, 2005 | 08:50 AM
irish44j's Avatar
retired moderator
here is my write-up. I used 6-ga multi-strand from one of those big reels at Home Depot...22 cents per foot (nothing fancy) and zing connectors. No need for gold ones unless you want the looks....
Old May 27, 2005 | 09:07 AM
S00NR1's Avatar
OU > *
I am one of those DIY'ers that followed Irish's how-to exactly and had good results. You can check my cardomain page for pics.
Old May 27, 2005 | 09:47 AM
dave's Avatar
i went with the active tuning kit, $40 and free shipping.
Old May 27, 2005 | 12:25 PM
bladerunr's Avatar
You can do it for less than $20 if you really want to. I called a few welding supply houses, found some black 6 ga. multi-strand cable, bought a bunch of ring teminals from NAPA and went at it. It's much more satisfying when you experiment yourself, especially when it won't harm anything if you f*&k up.
Old May 27, 2005 | 12:29 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I concur, DIY is the best way to go, plus you can accessorize the colors to your liking.
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
