Installed the STS.......got a question or two.....
Old May 29, 2005 | 10:56 PM
Maxima-Ness's Avatar
So I installed the STS today, but I ended up with a couple of questions...
First off, is it supposed to feel so stiff? Everything works fine and there are no problmes finding gears, it just seems really stiff.
Secondly, why does my shift **** shake a little in second?
Oh, update, I do plan on replacing the MT fluid with MT90. I already have it in my posession and plan on undertaking that project today.
Old May 29, 2005 | 11:14 PM
meccanoble's Avatar
Sports Button FTW
yea i gotta change my fluid too....
what STS do u have?
from what i read, it takes a little time for a new STS to break in? or maybe cause its a shorter shift it just feels stiffer? i'm awaiting replies from others as well....
Old May 29, 2005 | 11:55 PM
vsamoylov
what shifters you guys have?
Old May 30, 2005 | 05:35 AM
02SEleeper's Avatar
Mine shook going into second gear on a downshift, and was a little stiff going into reverse. It went away after replacing my clutch, flywheel and gear oil. I’m not sure if this was the reason or if it was just a matter of time.
vsamoylov, It's the HP Auto sts.
Old May 30, 2005 | 05:42 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Seeing as how you installed the bushings also, it ought to feel more stiff. It will most likely loosen up a bit as you use it but nowhere near the loose feel of OEM.
Not sure about the shaking shift ****.
Old May 30, 2005 | 06:12 AM
mjg's Avatar
mjg
This is either old news to you, or maybe not, but spraying white lithium grease will make it nice and smooth. It shouldn't feel "stiff" but the bushings will give you a more solid defined feeling. I finally did the grease thing this weekend... it had gotten so stiff i was hardly able to get this thing in reverse... now what a difference.
Old May 30, 2005 | 11:12 AM
Any particular place you sprayed it? I had heard it helped, but im just trying to figure out where to douse it....
Old May 30, 2005 | 12:48 PM
roll4life's Avatar
yea it will be stiff pretty much always
Old May 31, 2005 | 10:02 AM
zachary1988's Avatar
Mine was also very stiff. I read some where and lithium grease was recommended. I used it at bottom of shifter and under the hood and not any better. Very stiff. I talked to the person who designed the 02 STS and he asked me some questions and he was able to determine the problem. For me, I used one extra washer that I didn't need and it fixed the problem. The piece that goes under the hood I believe uses either one or two washers and I only needed one. Since then, mine shifts as it did before and didn't need any grease or bushings. I have the second gen STS, but I don't believe that should matter. Hopefully this hepls. Ed.
Old May 31, 2005 | 10:04 AM
chr0nos's Avatar
does this sts do the same thing as this one here:
http://forums.maxima.org/showthread....light=free+sts
i want to do this mod, and don't know if i should spend the money on an sts kit, or try the free mod first.
Old May 31, 2005 | 01:32 PM
Bluesbrekr's Avatar
Yes, they do the same thing.....relocate the pivot point.
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
