Car starts poorly, time for new starter?
Old Jun 1, 2005 | 06:48 PM
Whtmax'01's Avatar
When i start the car, it hesitates to start as if the battery was dead or low on power. The car always starts though, but i keep getting this hesitation now and then. Battery was changed about a year ago , so could it be the starter, and how do i make sure it is?
Old Jun 1, 2005 | 08:25 PM
Andrew's Avatar
well, as you explain it, it maybe the starter. What you should do, it to replace it anyway. When you take it out, go get it tested at Autozone or PepBoys or whatever. You may want to change this because you don't want to get stuck anywhere.
A-
Old Jun 2, 2005 | 08:29 PM
GimmeTorq's Avatar
The battery could still be the culprit or it could also be your alternator not putting enough juice out to charge it appropriately or there could be a electric equipment that may be draining current from your battery while the car is parked. Most battery shops can check for a battery going bad or charging system issues.
What kind of battery you bought?
Old Jun 3, 2005 | 05:13 AM
juniper9803's Avatar
Also Check Battery Terminals For Corrosion And Make Sure There Tight.
Old Jun 3, 2005 | 11:52 AM
ODB's Avatar
ODB
same problem here - have been living with it for a year
Old Jun 3, 2005 | 04:44 PM
paralyse's Avatar
I Miss My Maxima
Corrosion/buildup on battery cables, bad battery, or a bad ground. Remove and clean the battery cable terminals where they attach to the posts, and load-test your battery and charging system (free at autozone.)
Old Jun 3, 2005 | 06:15 PM
pull10k's Avatar
I have the same problem. I also hear a whir sometimes after the car starts that stops 2 or 3 seconds later. I know its not my battery since I had it replaced to see if that was it. (5 years old, had to go anyway)
Guess its $260 + labor for me.
Old Jun 3, 2005 | 08:36 PM
Built2prfctn's Avatar
Getting A Grounding Kit Might Help To
Lakersallday24
Jun 16, 2019 01:35 AM
acw
Aug 13, 2015 12:50 AM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
laparka66
Aug 6, 2015 09:36 AM
