Problem with Starter Removal *PICS*
Old Jun 6, 2005 | 08:11 AM
Pri63's Avatar
Well I did a TB cleaning and then moved on to the starter regrease...that's where I ran into a problem. I can't get the starter off! I took off two bolts and the grounding cable, as mentioned on motorvate's site. Can anyone help me on this one, ASAP?
Old Jun 6, 2005 | 08:51 AM
Love_00_Max's Avatar
Behind the starter are two bolts that need to be removed for the starter to come off. Note: I have never heard of regreasing the starter, I hope you meant regreasing the motor next to the starter--- right!!!
Old Jun 6, 2005 | 09:21 AM
Pri63's Avatar
thanks...i'll have to figure out a way to get a wrench back there...
Old Jun 6, 2005 | 10:50 PM
importuner
socket+extension+rachet= all you need. i believe u need both 14+17mm sockets. i forgot
Old Jun 7, 2005 | 07:48 AM
Ka$hThaRipper's Avatar
yeah those aren't the two bolts you need to take off..
the two bolts you need to take off aren't visible in your pic and you will need a swivel joint and it's preferable to use a breaker bar (its tight) to get it out
Old Jun 7, 2005 | 11:06 AM
Pri63's Avatar
Yeh all true, I was able to get the 14mm bolt out but din't have the right tools for the 17mm so I ended up not getting it out...
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
Colossus
Sep 9, 2015 05:46 AM
jwright36
Sep 8, 2015 11:45 AM
