Car start to vibrate at 50+mph since tire rotation
Old Jun 9, 2005 | 12:08 AM
siren001's Avatar
I just got my tired rotated, I have Pilots A/S 225ZR50R16 and for some reason when I go above 50 you can feel a vibration in the wheel and somewhat in the car. and its goes stronger the faster it goes.
Any Ideas? You think they knocked off a balancing weight?
Bad Struts?
Old Jun 9, 2005 | 12:11 AM
FanaticMadMax's Avatar
Yes, your car tires need to be balanced. I had that kind of problem on my mercedes and turned out that they were out of balance, I ended up getting a blow out cuz i didn't take care of it cuz i putting it off.
Old Jun 9, 2005 | 12:14 AM
siren001's Avatar
they said they were balanced too. Costco those ****
Old Jun 9, 2005 | 12:18 AM
HNDA ETR's Avatar
Still Here... IM me for more..
one of the balancing weights probably fell off...
Old Jun 9, 2005 | 12:20 AM
siren001's Avatar
I get the day off tomorrow I gonna take it back.
Old Jun 9, 2005 | 12:21 AM
siren001's Avatar
any other ideas incase they say they are all balanced?
Old Jun 9, 2005 | 01:19 AM
okay's Avatar
probably isn't this.... but its free to check, jack up your car and hold the wheel at the top and bottom try to wiggle each one back and forth if there is any play in the wheel then its your wheel bearings. do this for each wheel.
although the symptoms dont sound like it would be a wheel bearing, my car started vibrating on the freeway and it was the first signs of bad wheel bearings for me.
Old Jun 9, 2005 | 01:24 AM
siren001's Avatar
its vibrates and the steering seems a little loose.
Old Jun 9, 2005 | 03:42 AM
zgrm100's Avatar
It could be 2 things. Same hting just happened to me and also at costco. One, balancing could be off, mine was... Make sure you loo at the computer when they are doing it so that it shows 0... The second thing is that you could have a screwed up RIM. thats what I had too. You dont feel it so much when its in the rear but when they roatated and brought it forward thats when you would start to feel it.
Old Jun 9, 2005 | 02:29 PM
siren001's Avatar
when I was looking at them doing the balancing it would be like .8 to .4 on both sides on the computer screen. I should tell them to balance it better yah?
Old Jun 9, 2005 | 02:32 PM
zgrm100's Avatar
yep. IT should be perfect! All 0's they are lazy so make sure you watch them do it.
Old Jun 9, 2005 | 02:34 PM
siren001's Avatar
Can a person complain to them an not get intouble for making a stink about it?
Old Jun 9, 2005 | 02:35 PM
siren001's Avatar
or should i just say scew costco and go somewhere else? and spend money. when costco is suppose to cover the tire balance and rotation when you buy new tires.
Old Jun 9, 2005 | 02:43 PM
95bkackmax18s's Avatar
heck yea, they should of done it right.like you said maybe just go somewhere else or do the right thing and bring it to their attention. are we talking about the weights on the rim? what if you have no weights? good/bad/nothing major?
Old Jun 9, 2005 | 02:44 PM
siren001's Avatar
I get plenty on a few of the wheels, and like 1 or 2 on others.
Old Jun 9, 2005 | 02:47 PM
siren001's Avatar
cost of balance other than costco?
Old Jun 9, 2005 | 03:01 PM
HNDA ETR's Avatar
I believe there's a certain amount of margin that is allowed when balancing tires... I had the same thing happen and the guy told me that if it's within a certain margin, it's ok...
Old Jun 9, 2005 | 04:12 PM
zgrm100's Avatar
dont make a scene. It wont be a problem gettnig them re-balanced.
Old Jun 9, 2005 | 05:20 PM
Galo's Avatar
Maxima Pilot
Our Maxes are veeeeerryyyyy sensitive to wheel balancing issues and will shake and shimmy with as little as a half-ounce (.5 on the computer screen) out of balance.
When the tires are first spun, the machine's readout will display what the tire/wheel asembly is out of balance by. So, if you see .75 and .50, it means the inner side of the tire/wheel is off by 3/4 of an ounce and the outer side (under the spokes) is out of balance by 1/2 of an ounce
The technician will affix the weights on the locations indicated by the machine after which he should (must) spin the tires again and if he got it right, the machine will indeed display 'zeer/zero'.
If you get shimmy even with tires/wheels showing 'zero/zero', time to find yourself a shop with a Hunter 9700 Road Force Analyzer, pay your 20 or 25 bucks a tire and get them road forced which is nothing more than a process to match the high point of the tire with the low point of the wheel thereby optimizing the tire's 'roundness' or centricity
Added on an edit: one of the reasons why I got rid of the Pilot A/S was because no one around here could get them to balance perfectly, so....you may have some out-of-round tires
Old Jun 9, 2005 | 06:40 PM
siren001's Avatar
I took it back to get them to rebalance, I said i wanted it to be within the .4 to .0 range. which is better than the .8 or 1.2 it was before. and they said its gonna take them 4 hours, its at the shop now so well see...
I like the tires though, they get good wet grip.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
