Hids in 00/01 Housing
Old Jun 14, 2005 | 09:28 PM
StAtiXz6's Avatar
How exactly would i beable to fit a D2R bulb in a Stock 00/01 Housing???
Old Jun 14, 2005 | 10:41 PM
ChromeSE5's Avatar
a d2r bulb that is rebased to H4
Old Jun 14, 2005 | 11:30 PM
StAtiXz6's Avatar
how you do that???
Old Jun 14, 2005 | 11:55 PM
BudVlad's Avatar
I wouldn’t do that. You will lose high beam beside that the reflectors aren’t designed for HID. There are good write-ups about this problem on HIDplanet.com
Old Jun 15, 2005 | 06:10 AM
StAtiXz6's Avatar
meh its cool doesnt matter to me. I just wanna put hids in my stock housings.
Old Jun 15, 2005 | 06:22 AM
Redstone's Avatar
Yeah that's true. You won't have any high beams. Remember the 5.5 gen have a double headlight configuration which gives you a separate lense for the low beam which is H.I.D and a separate lens for the high beam (non HID). As you already know your 00/01 has a different set-up. Unless you could find a way to fit the new 6th gen bulb in your 00/01 housing since the 6th gen have bi-level xenon and it believe if you use the 6th gen bulb, it is much more complicated than just putting in a bulb. But don't quote me on on the 6th gen part just in case someone out there has found a way to modify it and make it work. Good luck!
Old Jun 15, 2005 | 07:04 AM
ChromeSE5's Avatar
ask larrio... he put HIDs in his 2k1 AE...
I dont recommended either but if you really want to do it you buy a d2r bulb that is rebased for h4 sockets. Also, i think its recommended to use a casper shield.
Old Jun 15, 2005 | 02:50 PM
MIXXMAX's Avatar
Yeah, there's no way you can put a D2R bulb in the 2k-2k1 headlamp housings. Even if you retrofit in a H4 socket, where is the high beams? Also, the HID bulb is not made for the lens either. Installing this bulb in this kind of lens would probably give you a weird beam pattern. It'll probably put glare all over the place.
Old Jun 15, 2005 | 02:54 PM
2kprlmax's Avatar
as long as when you order then you tell them they are for h4 bulb size they fit right in.
Old Jun 15, 2005 | 04:32 PM
ColdSHO's Avatar
u can just get a hid kit for h4s, as long as u keep the reflectors in, the glare isnt bad
Old Jun 15, 2005 | 06:51 PM
StAtiXz6's Avatar
D2R bulbs do work. My boy has it in his stock 00 housing but he got some hid adpator off ebay to make it work. Now we cant find out where to get them.
Old Jun 15, 2005 | 06:58 PM
GuZo's Avatar
So is a HI/LO kit possible to be fit in a 2K1 AE headlight?
Old Jun 16, 2005 | 05:37 AM
2kprlmax's Avatar
yes when you order it tell them it is for a h4
Old Jun 16, 2005 | 10:14 AM
ColdSHO's Avatar
u can get h4 with both highs and lows, but the the highs are useless, dont bother wasting money on the high/low, or(bi-xenon) just get the standard low kit, if u want more light, get another set of fogs or soemthing, the high/low kit isnt like the stock high lows
Old Jun 16, 2005 | 10:25 AM
StAtiXz6's Avatar
k imma try that but i can get a D2R bulb and pop it in the housing correct?
Old Jun 16, 2005 | 11:25 AM
GuZo's Avatar
I wanted to get a HI/LO kit in order to still pass inspection.
Old Jun 16, 2005 | 11:57 AM
Larrio's Avatar
The Definitive AE Master
search for casper electronics if you want a d2r bulb socket with h4 housing. Its shielded at the right angle also for the right beam pattern with no glare. Or you can search around ebay for people that sell it
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
